Correct MPLS for Middle school
Does anyone know the correct playlist for Middle School redox edition ?
Re: Correct MPLS for Middle school
Looking for it too.... no windows box to try to use the process explorer method.... any other way to find out?
davefaust78
I ran into some trouble with this today. Process Monitor saw 00994.mpls as it was playing on PowerDVD, but MakeMKV didn't have a 00994.mpls option.
spent over an hour piecing together the segments in the correct order,
Try:
Name: Middle School (English)
Source file name: 00925.mpls
Duration: 1:31:48
Chapters count: 12
Segment count: 21
Segment map: 500,512,514,519,508,503,513,510,505,502,511,516,515,520,509,501,506,504,507,517,518
File name: Middle_School_t203.mkv
Try:
Duration: 1:31:48
Chapters count: 12
Segment count: 21
Topher wrote:spent over an hour piecing together the segments in the correct order,
Try:
Duration: 1:31:48
Chapters count: 12
Segment count: 21
It looks like 00925.mpls and 00994.mpls are the same segment map. Is this confirmed to be the correct playlist?
ripitagain
MPLS 925 for RB doesn't appear to be correct. At 00:19:57 The actor is driving his BMW singing "I ain't got no time" then it cuts to the same actor washing the car with the kids sitting on the porch. It's possible that the movie just does quick cuts from scene to scene but it feels off.
Also, looking through the logs, MakeMKV posts that 925 is equal to 994, it's assume then, 994 is incorrect as well.
Any other MPLS ideas? (Thanks)
I am looking for confirmation as well.
I just played a rip of 925 along side the actual bluray and it matches up perfectly. The mentioned cut at 19:57 is present on both.DAlba wrote:I am looking for confirmation as well.
ripitagain
Thanks for the double-check
Running with 925
Running with 925
I have a retail edition of this, and the highest mpls that might be correct is 00898. All playlists have 520 as the first segment. If anybody else has a retail copy and wants to help, that would be fabulous, else I'll probably just shelve it for now and come back to it when I have time to dig into it.
Bumping because I'm borrowing the Retail Version from my local library and would like to know the correct playlist ASAP.
caffeinated
ProcMon said 737.
That lines up with 647
That's the one I'm trying.
Segment map: 520,505,512,501,500,518,516,507,504,519,508,515,503,510,506,517,513,509,514,502,511
I used this Source file name: 00925.mpls thanks.
As I just had selected the 1st track and all was good until we watched the movie and at the 1:05 point things were not in sequence.
Thanks again!
Thanks again!
Any idea on the correct one?
Axehandler
This is Correct
Title information
Duration: 1:31:48
Chapters count: 12
Segment count: 21
File name: Middle_School_t204.mkv
Title information
Duration: 1:31:48
Chapters count: 12
Segment count: 21
