MakeMKV can't keep up with fast M2 drives?
Tyrindor
#1 Post by Tyrindor » Tue Jan 03, 2017 10:08 pm
I have two 960 PROS, and transferring between them in windows I get 2GB/s. If I put an ISO on one, and the destination on another, I get about 750MB/s in MakeMKV. Processor usage doesn't exceed 20%. If I queue up 4 instances of MakeMKV, the total adds up to about 2GB/s.
Should be getting 2GB/s with one instance of the program. Doesn't seem like it's coded to take advantage of these fast speeds?
Tyrindor
Re: MakeMKV can't keep up with fast M2 drives?
#2 Post by Tyrindor » Tue Jan 10, 2017 9:29 pm
Bump, any possible fixes? MakeMKV advertises that it will go as fast as your drive on the main website and that doesn't seem to be true at these speeds. Any way to contact the developer to let him know?
MKVToolNix on the same setup remuxes an entire 50GB MKV in about 23 seconds. It's definitely MakeMKV. :(
#3 Post by Woodstock » Wed Jan 11, 2017 1:50 am
Fastest way to get Mike's attention is email - support@makemkv.com
