Use MakeMKV via Handbrake
BaturalNoobs
Post by BaturalNoobs » Tue Jan 03, 2017 2:38 pm
I'm trying to follow this guide to use MakeMKV through Handbrake. Specifically, I ran these commands:
mkdir -p ~/lib
ln -s /Applications/MakeMKV.app/Contents/lib/libmmbd.dylib ~/lib/libaacs.dylib
ln -s /Applications/MakeMKV.app/Contents/lib/libmmbd.dylib ~/lib/libbdplus.dylib
Next I:
- Open Handbrake
- Click Source
- Click the Blu-ray (i.e. CARS_USA)
- Click Open
- I get the error message "No Valid Source Found"
I posted about this over on the Handbrake forum and was told to "Run it though MakeMKV first."
Is there a way to use MakeMKV via Handbrake?
P.S. I'm running:
- macOS 10.12.3
- Handbrake 1.0.1
- MakeMKV 1.10.4 with license
Re: Use MakeMKV via Handbrake
Post by Woodstock » Tue Jan 03, 2017 3:31 pm
While I have experimented a couple of times with using MakeMKV as "translator" for other programs, I don't recall it working well in that role. There are issues with your buffer settings, such as having to make them small or you get time-out problems when the disk spins down while the buffer empties. My tests were with VLC.
After doing that, though, my main question I would have is, "Why?"
MakeMKV can rip to disk very quickly, then handbrake can take the MKV file as its input. Or, with Bluray, you can do a "backup" and let handbrake work from that. Either way, handbrake won't have to wait on the disk, and the rip won't have to wait on handbrake.
BaturalNoobs
Post by BaturalNoobs » Tue Jan 03, 2017 4:12 pm
Woodstock wrote:After doing that, though, my main question I would have is, "Why?"
The biggest reason would be just to save a step. I read about this setup and it sounded pretty cool so I gave it a try but couldn't get it to work. What you wrote makes sense though and I'd certainly prefer the most efficient way of doing this over the easiest way.
Thanks for your reply :D
cplr300
Post by cplr300 » Wed Jan 11, 2017 11:46 pm
This used to work, the problem is Handbrake 1.0. If you can find a version of Handbrake < 1.0, these steps work just fine.
There was a previous thread mentioning this: http://www.makemkv.com/forum2/viewtopic ... 10&t=15544
