Hunger Games Mockingjay Part 1 - US Retail (title)
Vandement
Re: Hunger Games Mockingjay Part 1 - US Retail (title)
Post by Vandement »
I know, I'm late to the party. I'm unable to rip Mockingjay Part 1. I've tried 553.mpls, 697.mpls, and 707.mpls. None work. I'm not technical – I don't even know what a segment is – so I don't really know what I'm looking for. MakeMKV 1.10.2 even points you to the "main feature," and it won't work. (The main feature is 697.mpls.)
I'm on a Mac.
Any guidance would be appreciated. Thanks!
abirdie4me
Post by abirdie4me »
woodmtw wrote: I purchased the 6-Disc Blu-ray + Digital HD "The Hunger Games, Complete 4-Film Collection" from Walmart in Utah, USA on 4/2/2016.
The UPC code is 0 31398 23837 9.
Here are the correct .mpls numbers:
You are awesome! I created an account on this forum to say THANK YOU, you saved me a ton of time. I have this exact UPC from Walmart and tried 4 combinations of Hunger Games that were wrong before finding this post.
eikki
Post by eikki »
Vandement wrote:I know, I'm late to the party. I'm unable to rip Mockingjay Part 1. I've tried 553.mpls, 697.mpls, and 707.mpls. None work. I'm not technical – I don't even know what a segment is – so I don't really know what I'm looking for. MakeMKV 1.10.2 even points you to the "main feature," and it won't work. (The main feature is 697.mpls.)
I'm on a Mac.
Hey me too! can anyone please help
sveighten
Post by sveighten »
IrishPrince wrote:As an academic exercise I tried the Netflix version of Mockingjay Part 1. The correct title is 697:
Name: The Hunger Games: Mockingjay - Part 1
Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
File name: The_Hunger_Games_Mockingjay_-_Part_1_t417.mkv
For those looking, keep in mind that makemkv doesn't sort by mpls, so you might have to look around. I found 696 and 699 or something and assumed that 697 was missing. Turns out the list just wasn't sorted.
efmullen
Post by efmullen »
Ripped the below and watched whole movie side by side with BluRay. Everything matched up correctly. Good luck! Thank you everyone for your help!
UPC:0 31398 20644 6 80
Title information
Source file name: 00553.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 503,520,516,510,511,506,507,514,518,509,519,517,501,505,502,512,515,504,513,508
File name: The Hunger Games- Mockingjay - Part 1_t293.mkv
libreme
Post by libreme »
How do you guys identify segments and how do you determine which is the correct one?
Poker354
Post by Poker354 »
libreme wrote: Wed Oct 23, 2019 4:07 am How do you guys identify segments and how do you determine which is the correct one?
Read the thread "A better way to find the correct playlist/segment map" found in the "MKV file processing and playback" section.
libreme
Post by libreme »
efmullen wrote: Wed Oct 02, 2019 8:05 pm Ripped the below and watched whole movie side by side with BluRay. Everything matched up correctly. Good luck! Thank you everyone for your help!
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
00553.mpls didn't work for me
jstrot
Post by jstrot »
Chilkoot wrote: Thu Aug 20, 2015 7:05 pm
Batiatus wrote:I figured out the Canadian Eone disc by ripping a couple versions, going through each scene and figuriing out where the streams change and then setting up the proper order. Had it written down and ripped it to find it was perfect. Then forgot to update here and my garbage has been taken out. D'oh! I 'think' it was like 320 or something. Lionsgate is just dumb for doing this though. Stupid dumb.
I went through the same exercise and you're memory's spot on. For the Canadian EOne version:
Playlist:  320
Filename:  t176
Order:     519	514	509	511	501	518	510	502	507	506	503	512	508	517	504	515	513	516	505	520
Hopefully this saves someone else the pain of undiscombobulating the whole mess again!
I think you're mistaken, I believe the correct playlist is 302 (not 320) for the Canadian eOne version. UPC: 7 74212 93644 9
Title information
Name: The Hunger Games: Mockingjay - Part 1 (English)
Source file name: 00302.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 519,514,509,511,501,518,502,510,507,512,506,503,508,504,517,515,513,516,505,520
I just went through this exercise on Linux:
- extract a decrypted backup: makemkvcon backup --decrypt dev:/dev/sr1 backup-folder
- extract the info to a text file: makemkvcon info --robot file:backup-folder > info.txt
- isolate and sort segment orders: grep -E 'TINFO:[0-9]+,26,0,' info.txt | sort -t , -k 4 > orders.txt
- being sorted, the segments are like a tree... manually go through the segments, checking against the movie playing on a physical BD player, adding up lengths to track the position and prune "branches" as you go until you're left with only one possibility
- the first number on the "winning" TINFO line is the title number, look for TINFO:<title#>,16, in the info.txt file to get the corresponding playlist
Once the backup was extracted, the rest of the process took about 10 minutes.
Cave Man
Post by Cave Man »
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
I have this same UPC Blu-ray Disc but the segment map is different for t293:
503,519,511,502,514,510,512,518,515,504,513,506,505,501,517,520,509,507,516,508
Will t293 still work, or do I need to figure out another title track?
Usually what you're looking for is a title that has the same segment map, not the same title name. So look through the other titles until you find the one with the same segment map.
eshcabeebee
Post by eshcabeebee »
Source file name: 00707.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
File name: The Hunger Games- Mockingjay - Part 1_t379.mkv
This is the one that worked for me with the upc code 03139820644680.
azbiker57
Post by azbiker57 »
Looks like I may have a different US retail version than some others.
UPC: 0 31398 20925 6
Source File: 00697.mpls
Duration: 2:02:50
Chapter Count: 16
Segment Map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
Xehelios
Post by Xehelios »
For the BD in the UHD/BD set sold on Amazon Canada
UPC: 0 31398 25278 8 82
Duration: 2:02:50
Chapters count: 16
Segment count: 20
File name: The Hunger Games- Mockingjay - Part 1_t141.mkv
And for those who are new to this, here's how to get to it. Assuming you are on macOS, have VLC, and it can play Blu-ray discs, run
env -u JAVA_HOME BD_DEBUG_MASK=0x40 /Applications/VLC.app/Contents/MacOS/VLC 2>&1 | grep -i mpls
Then, in the newly opened VLC window, press Cmd+D to open disc (or File -> Open Disc), open the BD disc, and then play the movie. The right .mpls file name will appear in the terminal. Quit VLC.
Then, (assuming you already have a decrypted backup of your disc that you made with MakeMKV) , in the Terminal
cd /Applications/MakeMKV.app/Contents/MacOS
Then run
./makemkvcon info --robot file:"folder of your decrypted backup" > ~/Desktop/info.txt
You can then open the info.txt file and search for the .mpls and see the Title number associated with it. Since MakeMKV sorts by title number, that makes finding the right playlist far easier.
