Has anyone had success making an MKV from the retail disc of The Sound of Music 50th Anniversary Edition?
I've tried using the latest versions of MakeMKV (as of Dec. 30 2016) on both a Mac and Windows machine, and receive the same "disc failed to open" error on both. I found an older thread regarding this title noting the need for a disc-specific SVQ file, but my understanding is the current versions of MakeMKV download any necessary SVQ files automatically now.
Happy to provide a log file if this is an unknown problem.
Thanks,
R
Sound of Music 50th Anniversary -- disc fails to open
thinksinc
Re: Sound of Music 50th Anniversary -- disc fails to open
"Fail to open" would not be a BD+ issue, which is where the SVQ files com into play.
Information from the debug log would be helpful - see the FAQ in my signature for more information on that.
This topic may help, too: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
thinksinc
Here's the log file. Let me know if I should also send a copy to support@makemkv.com.
Debug log started at Sat Dec 31 05:53:38 2016 , written by MakeMKV v1.10.4 darwin(x86-release)
001005:0000 MakeMKV v1.10.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Robert/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE12LU30 4261d" opened in OS access mode.
DEBUG: Code 2147483648 at e`7Z9'Hk'j6QAP|o:121265315
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=EHX1NJtdw4V57x18zX1nHMsLlqQVF4XvrutyF8HSYmoXGjFrIKuEQqYl067UdaBIzQe/PDvKpAAsXhWDgdY+QsQZE4krbrBTOBc/8h0rQM51As3OWcjb6wEWqKnyUjgP2NuI8/WLXfRt/nf9EfqtllCPznEiDDb0IQ==
DISCID=C0489AB229919C644FF4B804E4828CC6E0D5B835
003025:0000 Title #00191.mpls has length of 76 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00280.mpls has length of 28 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00190.mpls has length of 152 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00300.mpls has length of 2987 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00317.mpls has length of 2987 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00203.mpls has length of 2987 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00204.mpls has length of 2987 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00107.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 76 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00077.m2ts has length of 18 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00078.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00149.m2ts has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00172.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00072.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00084.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00085.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00086.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00087.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00088.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00089.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00090.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00150.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00151.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00152.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00153.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00280.m2ts has length of 28 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 2982 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00201.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00192.m2ts has length of 76 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00290.m2ts has length of 30 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00174.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00801.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
DCE=zn/GftyfZ4a4aqqq7dGVKpDgZWtyrXEWdIX0GJugjR4DN8yU8Alui6LmIQB9urrrb+q7ZGn2AEfWyxbCtXOLbf8Fvr+2Tov4AkKipeAYB1x+gqg1W/dfrxTuGkG+0x4ypL8IOrPv23qHENzaPbLQx2rVT5+++kG8zQ==
Application exited at Sat Dec 31 05:54:26 2016
Are you sure you are opening the feature disk, and not the extras disk? Your 1 hour minimum length exceeds all of the titles found. Try reducing the minimum length to 1800 and see if it opens the disk.
