Monsters, Inc
NutFlush920
Monsters, Inc
#1 Post by NutFlush920 » Mon Mar 26, 2012 5:29 pm
Does anyone know the proper segment order for Monsters, Inc blu-ray here in the US?
NutFlush920
Re: Monsters, Inc
#2 Post by NutFlush920 » Mon Mar 26, 2012 9:08 pm
I found this... I hope it's correct as I couldn't find anyting on AVS's site for the USA version.
http://irfree.net/threads/38007-Monster ... TS-HDMA5-1
Smithcraft
Re: Monsters, Inc
#3 Post by Smithcraft » Tue Mar 27, 2012 8:07 am
brellyn
Re: Monsters, Inc
#4 Post by brellyn » Fri Dec 30, 2016 12:14 am
Smithcraft wrote:AVS forum US version.
http://www.avsforum.com/avs-vb/showpost ... tcount=766
SC
I can't tell you how frustrating it is to have to follow links to other sites to get the answer to a simple question.
this link from the 2nd post http://irfree.net/threads/38007-Monster ... TS-HDMA5-1 is dead.
the link quoted is confusing and doesn't answer the question.
There are three sources, 800, 802 and 803. Which is correct?
Re: Monsters, Inc
#5 Post by Woodstock » Fri Dec 30, 2016 1:16 am
Which language do you want?
English will be 800. This is standard Disney animation protocol. The versions are identical except for the titles and credits, and sometimes signs within. 800 has the titles and credits in English. The others can be Spanish, French, or German, depending upon the disk, but you can tell by looking at the titles.
brellyn
Re: Monsters, Inc
#6 Post by brellyn » Fri Dec 30, 2016 2:00 am
Woodstock wrote:Which language do you want?
Beautiful. I wanted English and that's 800. Exactly what I needed to know. Thanks! :D
Lovely Rita
Re: Monsters, Inc
#7 Post by Lovely Rita » Fri Dec 30, 2016 2:56 am
brellyn wrote: I can't tell you how frustrating it is to have to follow links to other sites to get the answer to a simple question.
Yes but did you happen to notice that the post you're referencing is almost 5 years old?
Registered User :wink:
Buy MakeMKV
