As title says, it doesn't install but keeps saying "The selected installation directory is not empty. bla bla bla" but the directory is empty ...
So, what to do ???
1.10.4 doesn't install
Re: 1.10.4 doesn't install
What did you answer when you were asked to uninstall the previous version?
The last 15 or so versions have required that the install directory be empty, which means uninstalling the previous version, OR specifying a new install directory, if you want to have multiple versions available.
Any control files you modify (profiles) should be kept in your MakeMKV data directory (found in Preferences->General).
Siddus
No other versions, this is my first try with makemkv ...
