High memory usage, 600 MB
stax76
Post by stax76 »
Why does it use so much memory? I use Win 7 x64 with only 2 GB memory so it might be problematic using other high memory applications in parallel.
Re: High memory usage, 600 MB
Post by mike admin »
You may change amount of memory used for buffering in preferences.
stax76
Post by stax76 »
Thanks, I'll try 256 MB.
There are some minor UI issues using 144 DPI, might be QT related.
http://msdn.microsoft.com/en-us/library ... 85%29.aspx
davidgreem
Post by davidgreem »
It is not possible if the system is perfectly working,you must check it out something is wrong with the system and check the buffer memory also.
stax76
Post by stax76 »
What are you talking about?
Which process memory usage are you talking about, makemkv , makemkvcon or both?
stax76
Post by stax76 »
@mike admin
Who do you mean, davidgreem or me? What is makemkvcon?
