Read errors
horothewise
Read errors
Post by horothewise » Mon May 10, 2010 4:59 am
Hey all,
I have a disc that seems to keep having a read error at around the same location every time (Die hard 3 from the quadrilogy). I can't seem to get this disc to read around the same area, though the surface looks perfect. Is there a way to make MakeMKV ignore the read errors and continue reading past the bad spot?
setarip_old
Re: Read errors
Post by setarip_old » Mon May 10, 2010 5:57 am
Hi!
Try cleaning the disc first. If that doesn't do the trick:
Settings>>Read retry count
I'd suggest that you first try INCREASING it to 20...
mikeinessex
Re: Read errors
Post by mikeinessex » Mon May 10, 2010 1:30 pm
i have the quadrilogy region 2 uk, diehard 3 worked fine for me so it does work. have you got the most up to date software of makemkv? silly question but gotta ask. the only one i couldnt do was the diehard 4.0
