MKV 3D to 2D no video
spl147
Post by spl147 »
I decided to run all my 3D Mkv's through makemkv to remove the mvc stream and keep the 2D movie, when i play the movie i get audio but no video.
Any ideas?
Re: MKV 3D to 2D no video
Assuming you still have the original MKV files, I'd recommend using mkvmerge instead... Load the MKV file, uncheck the MVC track, give it someplace to put the resulting file, and just that one track will go away.
When you do this with MakeMKV, you may have your preferences for track selection take effect in ways you didn't mean to do. mkvmerge doesn't have those issues, since it doesn't "do" preferences like that.
spl147
Post by spl147 »
Woodstock wrote:Assuming you still have the original MKV files, I'd recommend using mkvmerge instead... Load the MKV file, uncheck the MVC track, give it someplace to put the resulting file, and just that one track will go away.
original 3d mkv's are gone. I used the default profile. it something in the header perhaps? it plays on my pc, but not on my duneHD 4K Solo Lite
here is the mediainfo output:
General
Unique ID                                : 244573690771880092140062474611906505699 (0xB7FF2DF1875E8BEAA8149BFA4E5AEBE3)
Complete name                            : /Volumes/Video/Movies/Blu-ray/TRON Legacy/TRON Legacy.mkv
Format version                           : Version 2
File size                                : 26.2 GiB
Duration                                 : 2h 5mn
Overall bit rate                         : 30.0 Mbps
Movie name                               : TRON Legacy
Encoded date                             : UTC 2016-12-08 23:17:24
Writing application                      : MakeMKV v1.10.2 linux(x64-release)
Writing library                          : libmakemkv v1.10.2 (1.3.3/1.4.4) x86_64-linux-gnu
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Format settings, GOP                     : M=1, N=12
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 2h 5mn
Bit rate                                 : 24.3 Mbps
Maximum bit rate                         : 31.0 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 (24000/1001) fps
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.488
Stream size                              : 21.2 GiB (81%)
Audio
Format                                   : DTS
Format profile                           : MA / Core
Mode                                     : 16
Format settings, Endianness              : Big
Duration                                 : 2h 5mn
Bit rate mode                            : Variable / Constant
Bit rate                                 : 5 731 Kbps / 1 509 Kbps
Channel(s)                               : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Frame rate                               : 93.750 fps (512 spf)
Compression mode                         : Lossless / Lossy
Stream size                              : 5.01 GiB (19%)
Menu
00:00:00.000                             : en:Chapter 01
00:04:07.163                             : en:Chapter 02
00:14:44.049                             : en:Chapter 03
00:23:15.602                             : en:Chapter 04
00:26:52.694                             : en:Chapter 05
00:36:12.211                             : en:Chapter 06
00:38:35.980                             : en:Chapter 07
00:46:52.726                             : en:Chapter 08
00:53:03.763                             : en:Chapter 09
01:04:54.181                             : en:Chapter 10
01:13:47.423                             : en:Chapter 11
01:19:00.944                             : en:Chapter 12
01:22:40.455                             : en:Chapter 13
01:25:50.895                             : en:Chapter 14
01:28:11.828                             : en:Chapter 15
01:31:42.413                             : en:Chapter 16
01:43:13.061                             : en:Chapter 17
01:48:18.033                             : en:Chapter 18
01:54:48.381                             : en:Chapter 19
01:58:03.659                             : en:Chapter 20
spl147
Post by spl147 »
spl147 wrote:I decided to run all my 3D Mkv's through makemkv to remove the mvc stream and keep the 2D movie, when i play the movie i get audio but no video.
Any ideas?
ALL of them play fine on a pc/mac player as wel as on the mede8er x3d, just not on the dune solo lite
