Ice Age Collision Course
iMactouch
Re: Ice Age Collision Course
Post by iMactouch » Fri Nov 11, 2016 4:14 pm
Woodstock wrote:You should have gotten a "No FUTs" message in this case.
Yes, I got it.
Woodstock wrote:Do you allow MakeMKV to check for updates? Preferences->General, "Allow contacting web server for updates" should be checked, so that MakeMKV can look for the proper SVQ file to deal with this "final line" of copy protection.
I have checked that, but I have still no luck!
What can I do now? Only wait?
... a little bit later I found another thread regarding FUTs and now I send the dump file to the eMail-address.
iMactouch
Post by iMactouch » Mon Nov 14, 2016 8:02 pm
After sending three different svq files the Bluray is now working!
Thank you very much!
jhughy2010
Post by jhughy2010 » Sat Dec 10, 2016 8:10 pm
I'm confused (I think) on how to send svq files.... I too am getting the pop up warning for FUTS and the resulting MKV movie file has distortion.
Post by Woodstock » Sat Dec 10, 2016 10:58 pm
At this point, you should not need to send an anything in, but you do need to allow MakeMKV to contact the server to pull in the correct SVQ file. That's controlled in Preferences->General, "Allow contacting web server for updates" should be checked. Not everyone wants to leave this enabled - but it needs to be turned on when MakeMKV needs to pick up SVQ files.
In the unusual circumstances that your copy of this title needs a different SVQ than has already been generated, you will see the path to the file that needs to be submitted in the error log from the rip. That file gets emailed to svq@makemkv.com for Mike to review.
yorgo
Post by yorgo » Sat Dec 10, 2016 11:01 pm
jhughy2010 wrote:I'm confused (I think) on how to send svq files.... I too am getting the pop up warning for FUTS and the resulting MKV movie file has distortion.
Please see this link: /svq/
jhughy2010
Post by jhughy2010 » Sun Dec 11, 2016 5:33 am
Woodstock wrote:At this point, you should not need to send an anything in, but you do need to allow MakeMKV to contact the server to pull in the correct SVQ file. That's controlled in Preferences->General, "Allow contacting web server for updates" should be checked. Not everyone wants to leave this enabled - but it needs to be turned on when MakeMKV needs to pick up SVQ files.
Ok yes I have checked that and the box was/is checked.
I'll email the file.
jhughy2010
Post by jhughy2010 » Tue Dec 13, 2016 4:35 am
I emailed a few days ago and no response. Any idea how long it takes to get the specific SVQ?
jhughy2010
Post by jhughy2010 » Sat Dec 17, 2016 9:05 pm
I tried the none 3D Blu Ray and the movie ripped fine with no FUTs errors. The 3D remains an issue.
