I currently remuxed one of my BluRay with MakeMKV 1.10.2. It is fine but I get "Statistics Tags Issue" line and other lines below (FromStats_BitRate, FromStats_Duration...) which appear for Video but also different Audio. Is there a way to avoid these tags before or afterwards (delete them ?)) ? Are all MakeMKV versions using these tags ?
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=10
Codec ID : V_MPEG4/ISO/AVC
Duration : 1 h 41 min
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : Yes
Forced : No
Statistics Tags Issue : MakeMKV v1.10.2 win(x64-release) 2016-12-11 12:06:36 / mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28 2016-12-11 12:30:39
FromStats_BitRate : 19952138
FromStats_Duration : 01:41:25.120708333
FromStats_FrameCount : 145897
FromStats_StreamSize : 15176394631
FromStats_OriginalSourceMedium_ID : 001011
