Delete Statistics Tags Issue
abel413
Post by abel413 »
I currently remuxed one of my BluRay with MakeMKV 1.10.2. It is fine but I get "Statistics Tags Issue" line and other lines below (FromStats_BitRate, FromStats_Duration...) which appear for Video but also different Audio. Is there a way to avoid these tags before or afterwards (delete them ?)) ? Are all MakeMKV versions using these tags ?
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=1, N=10
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1 h 41 min
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Statistics Tags Issue                    : MakeMKV v1.10.2 win(x64-release) 2016-12-11 12:06:36 / mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28 2016-12-11 12:30:39
FromStats_BitRate                        : 19952138
FromStats_Duration                       : 01:41:25.120708333
FromStats_FrameCount                     : 145897
FromStats_StreamSize                     : 15176394631
FromStats_OriginalSourceMedium_ID        : 001011
abel413
Re: Delete Statistics Tags Issue
Post by abel413 »
Actually it seems to come with MKVmerge as I remuxed something afterwards. But I am not sure.
ndjamena
Post by ndjamena »
The MKVMerge version you're using is ancient, it's not capable of dealing with the tags properly.
Unless you have a VERY good reason for using that particular version of MKVMerge you should be using the current one.
abel413
Post by abel413 »
ndjamena wrote:The MKVMerge version you're using is ancient, it's not capable of dealing with the tags properly.
Yes, indeed. Actually there doesn't seem to be a 'MKVmerge alone' but only MKVToolnix. I can't find MKVmerge alone without ToolNix, I guess it doesn't exist anymore byt itself ?
That's why I picked up that old MKVmerge which actually provides a MKV file I can play on my physical BD player (via an external hardware). Last version of MKVToolnix provides a great file but if I try to speed up the movie to reach a specific scene, it doesn't work with a speed > x2. With a x32 speed of navigation, the movie stuck and stops and I have to start it again. This doesn't happen with the MKV provided by that old MKVmerge version. I can speed and naviguate as much as I want. Do you have an idea what happens ? If I had not that issue, I will use MKVToolNix.
ndjamena
Post by ndjamena »
https://github.com/mbunkus/mkvtoolnix/w ... th-players
For a start.
abel413
Post by abel413 »
Do you mean I should use a command line via MKVToolNix with the different options from that link ? Actually I had a quick look but I have no idea for which reason it doesn't work. As I'm speeding up the movie, I guess my player doesn't try to reach some specific area or a key frame.
ndjamena
Post by ndjamena »
You don't need to use the command line. If you use the GUI there's an "additional options" option in the Merge Tool>>Output tab that lets you try each of the options using nothing more than a checkbox.
Try each of them, if you find one that works add it to
MKVToolNix GUI>>Preferences>>Default Values>>Default additional command line options
And you'll never have to think about it again (unless you actually prefer to use the command line, but it's best to figure out what works first, it could be anything, including maybe you misinterpreting what's been going on.... or not)
abel413
Post by abel413 »
ndjamena wrote:You don't need to use the command line. If you use the GUI there's an "additional options" option in the Merge Tool>>Output tab that lets you try each of the options using nothing more than a checkbox.
OK, well it will take a while then because I will have to try one setting then another one, remuxing each time...and copying mkv to my hardware to play it.
ndjamena
Post by ndjamena »
It should be worth it in the long run. You're missing out on 7 years of progress.
Do the makemkv files play fine? That could be a clue.
