Dirty Grandpa - Which is the right mpls?
rogodeter
Re: Dirty Grandpa - Which is the right mpls?
#16 Post by rogodeter » Thu May 26, 2016 12:59 am
DJRumpy wrote:Confirmed for UPN 31398244110, MPLS 573 is the correct one.
Thanks. Trying it now and will confirm when I view it later
spiceygas
#17 Post by spiceygas » Tue Jun 14, 2016 11:32 am
For Netflix, confirmed that the correct track is 410.
Watched the whole movie through to verify.
FatLibertarianDude
#18 Post by FatLibertarianDude » Mon Jun 20, 2016 1:10 pm
My copy is also the unrated version and all the segment maps start with 517.
I will give 573 a try and then report back if it worked for me.
FatLibertarianDude
#19 Post by FatLibertarianDude » Tue Jun 21, 2016 12:56 pm
I'm just here to confirm that mpls 573 worked for me.
My copy is the unrated version purchased online from Best Buy.
SeaLight
#20 Post by SeaLight » Tue Jul 05, 2016 6:00 pm
573 worked for me too for the unrated version. Thanks!
MakOwner
#21 Post by MakOwner » Sun Aug 07, 2016 8:25 pm
SeaLight wrote:573 worked for me too for the unrated version. Thanks!
How do you determine which title is "Playlist 573"?
When opening the BD in 1.1.10, I see in debug mode 307 titles opened, but nothing in the display for title selection has any sort of name other than "Title".
MonsterMaxx
#22 Post by MonsterMaxx » Fri Dec 16, 2016 11:19 pm
no 410 or 573 on netflix version
anyone know?
Thanks in advance
entryoversteer
#23 Post by entryoversteer » Sun Mar 19, 2017 5:42 am
My NF disc has no 573. See below result when I try 00410.
https://drive.google.com/open?id=0B228D ... 1NISTh5OHM
Lantesh
#24 Post by Lantesh » Fri Aug 07, 2026 12:47 am
DJRumpy wrote: Thu May 19, 2016 11:51 pm Confirmed for UPN 31398244110, MPLS 573 is the correct one.
I know I'm 10 years late replying to this topic, but thank you so much. I couldn't even get the disc to play on my PC in order to use Process Monitor to figure out the correct mpls, and I see others weren't getting the correct results with that anyway. I have the same sku as you. So I'm going with 573 as you suggested.
