The Sword in the Stone Blu Ray (Cannot be Decrypted)
ADAM12386
Hello
New to the Makemkv Forum! If any one can help it would be much appreciated.
I am having a problem with The Sword in the Stone (Disney Movie) Blu Ray Copy
I have had no problems with any other Blu Ray Movies up until now, MKV just keeps saying ( Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive Highest AACS version is v53 , MKB saved as /Users/adamnicholls/Library/MakeMKV/MKB_v53_LAST_KNIGHTS.tgz The volume key is unknown for this disc - video can't be decrypted) I have copied the log debug messages below.
Thanks Adam
MakeMKV v1.9.7 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/adamnicholls/MakeMKV_log.txt
Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
DEBUG: Code 0 at WKQW^c9mbz:nV Ix+r:29396345
DEBUG: Code 0 at WKQW^c9mbz:nV Ix+r:121262647
DEBUG: Code 1 at WKQW^c9mbz:nV Ix+r:121262647
DEBUG: Code 2 at WKQW^c9mbz:nV Ix+r:121262647
DEBUG: Code 3 at WKQW^c9mbz:nV Ix+r:121262647
DEBUG: Code 4 at WKQW^c9mbz:nV Ix+r:121262647
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FC33114EE4278E32A497CAE2C07BB94282 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
DEBUG: Code 0 at T}F;]<CE9vJ9">%+u:213130766
DEBUG: Code 0 at WKQW^c9mbz:nV Ix+r:29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09D2C5394D586E979610887D201576C4693 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0479D6AB1D9D364CCDA930023C45F1B809D to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EEE0EF56C8ACA5AC1A249B8FC977377074 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07D719CE0CB9C6C48BE04AF6D3F249FE605 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03B4A28B0DFA190F2B7C7608C4BD35A7545 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AA0F8D13F889A64F2778C07371DED67C4D to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BAB382562B54501B58A0B49F34E2CF6376 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09F2AC91CF4695395731FE1DD41CF37588E to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CB11560ADF1CEA7D23F38D32FA3F654305 to device 'IoKit:IOBDServices:35af551356e2e7c1:TSSTcorp BDDVDW SE-506BB TS00'
DEBUG: Code 0 at 'V%sU:vm4=.PZ3z3:121264073
DEBUG: Code 0 at 'V%sU:vm4=.PZ3z3:29397403
Thanks Adam
Re: The Sword in the Stone Blu Ray (Cannot be Decrypted)
Things start to go downhill here:
Any scratches (even minor) or dirt near the hub of the disk?
When trying to read part of the disk that MakeMKV needs to set up the key exchange, the drive said it couldn't read the disk.Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00514.m2ts' at offset '52955136'
ADAM12386
Hi
Thanks for your reply.
Nope the disk has no damage it is in perfect condition, I even brought a second copy to check if the first disk was actually faulty but the same thing happened again! Ive tried out other films to see if it was my drive that was faulty but everything else is fine and never had a problem in the past! Its rather annoying me though!!
eyeballtickler7
I have the same problem with this disc, is there any info I can give that will enable MakeMKV to copy it?
Happy to provide any info. Cheers
davocon
I have just tried to use MakeMKV on this Blu Ray and encountered the same problem. Any updates on this?
Are you also getting the read errors the original poster was getting?
davocon
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FD4F72B4BD05CC1E316BF623D071A04285 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05BFD521513C95D18A5B9E938324E66C727 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EE22C82B962E64D49B8A73EC520AA3316F to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B826AF31252455FA14316F9CDD25646D62 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AF546B0B8F35A9F9EFA1B5A69E4C2CE6BE to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07D4BB7E778735FBB022FDCDDBCA91844CF to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EB06CC49A155E84E4C68F417E7192F7CB6 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E9915ED8FCB17337D659EEA16F94C3E7D0 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..082AFD472FE760ED8F0E9F95DED17A00DA6 to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0910A3CF697E14E0BB109CEB756661754CB to device 'IoKit:IOBDServices:fec9ec9e1ee022ef:TSSTcorp BDDVDW SE-506CB TS02'
Highest AACS version is v57 , MKB saved as /Users/david/Library/MakeMKV/MKB_v57_THE_FORCE_AWAKENS.tgz
davocon
And it works fine with every other Blu Ray I've tried.
Lovely Rita
The log you posted is for "The Force Awakens" not The Sword and the Stone.
yorgo
And what version of MakeMKV are you on? Your log states:
"Highest AACS version is v57 , MKB saved as /Users/david/Library/MakeMKV/MKB_v57_THE_FORCE_AWAKENS.tgz
The volume key is unknown for this disc - video can't be decrypted"
As of version 1.10.2, it supports up to v62. If you're not on the latest version (now 1.10.3), you need to upgrade.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
"Highest AACS version" refers the highest version the particular installation has SEEN, not the highest version the running program supports.
yorgo
I stand corrected, thank you for pointing out.Woodstock wrote:"Highest AACS version" refers the highest version the particular installation has SEEN, not the highest version the running program supports.
Googled around and found this, posted earlier this year with reply by Woodstock, beginning to look like a disc-specific issue?
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=13482
davocon
Thank you for that post about Looney Tunes. I was able to backup the HD and then make the MKV from that. Not sure why it can read it to back it up but not to read it directly but it worked anyway so thank you.
