v1.10.3 3D bug?
Everything related to Blu-ray 3D and 3D MKV files
gingellr
v1.10.3 3D bug?
Post by gingellr »
I have just upgraded from 1.10.2 to 1.10.3
I ripped a 3D bluray but when the mkv plays it is unwatchable (left/right eye swapped maybe?)
I reinstalled 1.10.2 and re-ripped and the mkv worked correctly in 3D.
I again installed 1.10.3 and re-ripped again the new mvk was again unwatchable.
So it looks like there is a bug in 1.10.3?
thanks
Re: v1.10.3 3D bug?
To make sure Mike sees this quicker, I'd recommend sending an email to support@makemkv.com to get his attention.
mmartin
Re: v1.10.3 3D bug?
Post by mmartin »
I can confirm this bug, even when i select the MVC Video Track manually, only the main (2D) is copied to mkv file.
Reverting to v1.10.2 fixes the problem...
VAMET
Re: v1.10.3 3D bug?
Post by VAMET »
Dear Friends
Yes, it's true. 1.10.3 has broken MVC. Where can I download 1.10.2 and what are MD5 and SHA1 for this version, because I have downloaded it from unknown site and I would like to check it.
Thank you in advance.
Sincerely
yorgo
Re: v1.10.3 3D bug?
Post by yorgo »
/download/old/
dcleys
Re: v1.10.3 3D bug?
Post by dcleys »
I experience the same problems playing 3D MKV's ripped with makemkv 1.10.3. Video is not displaying correctly and audio is out of sync.
Re: v1.10.3 3D bug?
Post by mike admin »
This is a bug in 1.10.3 . Bug happens only if the source is 3D M2TS (SSIF) file (a 3D blu-ray disc). The stream data in produced MKV file is corrupted, and the level of corruption is disc specific. Some discs are not affected at all, others only have few bad video frames or subtitles, for some discs corruption is obvious. The 1.10.4 is out. Do not use 1.10.3 with 3D source, no matter if you are producing 3D or 2D MKV.
Hacket
Re: v1.10.3 3D bug?
Post by Hacket »
I managed to resolve 3D playback issues by manually switching the stereomode flag to sbs (using Kodi for playback). Ripped about 20 3D titles with 1.10.3.
