Miss Peregrine - BD+ Process no FUT
Azuroth
#1 Post by Azuroth » Wed Dec 14, 2016 1:39 am
Got a BD+ Processed but no FUT error, dump file already sent to svq@makemkv.com
TheDoc
Re: Miss Peregrine - BD+ Process no FUT
#2 Post by TheDoc » Wed Dec 14, 2016 3:30 pm
Having the same problem. It is a streetlock disk and will most likely need an update. They are having the same issue with AnyDVD and they just posted a patch. Hopefully we will see a fix soon.
garretn
#3 Post by garretn » Wed Dec 14, 2016 3:48 pm
Yeah, though I don't think the problem is related to Streetlock itself. Maybe a new BD+ protection?
Azuroth
#4 Post by Azuroth » Wed Dec 14, 2016 4:13 pm
I'm going with that makeMKV just doesn't have the right key to fully process the disk.
dmillionz
#5 Post by dmillionz » Wed Dec 14, 2016 11:52 pm
Where are we with this error? Just got my copy today and trying to get it in 3D MVC MKV format.
dmillionz
#6 Post by dmillionz » Thu Dec 15, 2016 10:24 pm
Anyone know how this issue is resolved? Not sure what to do to get around the issue. It did copy to 3D MKV properly despite the error but the playback is broken of course.
garretn
#7 Post by garretn » Thu Dec 15, 2016 10:44 pm
Well if you get impatient waiting for an update like I did, you can do a trial of AnyDVD HD and use that to rip the disc to your hard drive (I did it to a folder), then select that as your source in MakeMKV. If you haven't trialed AnyDVD before just download it's latest version from redfox and it'll ask if you want to trial it, then you have 21 days of full functionality. I personally don't use windows, but it worked fine in a windows 7 virtual machine (virtualbox).
The issues with ripping it appear to be an unsupported method of BD+ to me, but I'm sure Mike will release an update pretty soon if you'd rather wait.
dmillionz
#8 Post by dmillionz » Fri Dec 16, 2016 5:13 am
garretn wrote:Well if you get impatient waiting for an update like I did, you can do a trial of AnyDVD HD and use that to rip the disc to your hard drive (I did it to a folder), then select that as your source in MakeMKV. If you haven't trialed AnyDVD before just download it's latest version from redfox and it'll ask if you want to trial it, then you have 21 days of full functionality. I personally don't use windows, but it worked fine in a windows 7 virtual machine (virtualbox).
Great idea. Tried the same thing using DVDFab instead, which I already own, and it worked like a charm. Kids want to see it for winter break this weekend and this did the trick.
Thanks for the tip.
JayWalker
#9 Post by JayWalker » Tue Dec 20, 2016 4:30 pm
Azuroth wrote:Got a BD+ Processed but no FUT error, dump file already sent to svq@makemkv.com
Disc-specific SVQ (000001d9.svq) now finding 1 FUT. Will process disc and check results. Others here may also wish to re-try using latest SQV download.... SQV file update confirmed for my Amazon 2D/3D BD/DVD Combo package.
dmillionz
#10 Post by dmillionz » Tue Dec 20, 2016 9:10 pm
I'm a noob. How do I actually go about doing this?
yorgo
#11 Post by yorgo » Wed Dec 21, 2016 1:13 am
It sort of happens automatically. Try opening the disc with the latest version of MakeMKV and be certain you're connected to the internet.
dmillionz
#12 Post by dmillionz » Wed Dec 21, 2016 3:06 am
yorgo wrote:It sort of happens automatically. Try opening the disc with the latest version of MakeMKV and be certain you're connected to the internet.
It's working now in MakeMKV. Thanks.
bradleyrealtor
#13 Post by bradleyrealtor » Fri Dec 23, 2016 4:26 pm
:D Thanks, ditto that, works great now.
