Application not opening
NBA1527
#1 Post by NBA1527 » Thu Dec 08, 2016 4:30 pm
I have tried to remove and re-install MakeMKV and the latest updates but without any success and keep getting the following message. Could you please tell me how this is corrected?
'This application version is too old. Please download the latest version at / or enter a registration key to continue using the current version.
Re: Application not opening
#2 Post by Woodstock » Thu Dec 08, 2016 5:55 pm
Pick up the new beta key here: http://makemkv.com/forum2/viewtopic.php?f=5&t=1053
Copy it into your clipboard.
Set your system date back to 11/25. Start MakeMKV. You can set your system date to today after it starts.
Go to Help->Register, and paste the new key in.
Permanent fix is buying a key.
NBA1527
#3 Post by NBA1527 » Tue Dec 13, 2016 8:53 am
OK great thanks I'll try that, but I'm not tech savvy so bear with me.
How / where can I buy a key from?
#4 Post by d00zah » Tue Dec 13, 2016 11:32 am
'Help > Purchase' from the app menu takes you here:
/buy/
