300 blu-ray - 0 titles saved, 1 failed
dahlberg123
#1 Post by dahlberg123 » Sat May 08, 2010 3:58 pm
I am backing up my top 100 blu-rays for playback in W7 MCE using MediaBrowser but I can't seem to get my 300 blu-ray to rip, it seems to crap out 3/4 of the way in, any thoughts?
MakeMKV v1.5.5 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Tom/MakeMKV_log.txt
Evaluation version, 5 day(s) out of 30 remaining
File 00025.mpls was added as title #0
File 00021.mpls was added as title #1
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #2
File 00005.m2ts was added as title #3
File 00006.m2ts was added as title #4
File 00007.m2ts was added as title #5
File 00008.m2ts was added as title #6
File 00009.m2ts was added as title #7
File 00022.m2ts was added as title #8
Title #00023.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00028.m2ts was added as title #9
Title #00029.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory D:/Video/300
Error 'Internal error - Decryption error (411)' occured while reading '/BDMV/STREAM/00026.m2ts' at offset '13163888640'
DEBUG: Code 0 at CkTe1vDt(Qh8'5c<:213136769
DEBUG: Code 117834139 at Rl2q)LKK1>q+:K#;JM:213132445
DEBUG: Code 117834139 at Rl2q)LKK1>q+:K#;JM:29393654
DEBUG: Code 0 at u]o<9MIT<*WUM@Tm%8R!:213130628
DEBUG: Code 0 at T*TBHnLg^;?39>BhE'];:213129823
DEBUG: Code 0 at u]o<9MIT<*WUM@Tm%8R!:213130513
DEBUG: Code 6427680 at u]o<9MIT<*WUM@Tm%8R!:213129639
Failed to save title 0 to file D:/Video/300/title00.mkv
dahlberg123
Re: 300 blu-ray - 0 titles saved, 1 failed
#2 Post by dahlberg123 » Sun May 09, 2010 10:45 pm
nobody has any thoughts on this?
setarip_old
#3 Post by setarip_old » Sun May 09, 2010 11:15 pm
Hi!
Interpreting error codes is the bailiwick of "mike admin". He'll undoubtedly address this thread as soon as it's practical...
dahlberg123
#4 Post by dahlberg123 » Sun May 09, 2010 11:31 pm
setarip_old wrote:Hi!
Thanks, I searched and couldn't find similar errors but I figured someone might have come across this one before. I'll drink a few beers and patiently await a response :D
#5 Post by mike admin » Mon May 10, 2010 8:25 am
It looks like a problem with the disc. Were you able to make a decrypted backup from it?
dahlberg123
#6 Post by dahlberg123 » Mon May 10, 2010 4:02 pm
mike admin wrote:It looks like a problem with the disc. Were you able to make a decrypted backup from it?
The disc plays fine in my stand-alone blu-ray player but I haven't tried making a "decrypted backup" as MakeMKV is the only tool I currently use. If you tell me what software package I should try to make a backup with I can certainly do that.
setarip_old
#7 Post by setarip_old » Mon May 10, 2010 5:13 pm
Mike is asking you to try using MakeMKV's "Backup" function, with "Decrypted" selected:
1) Start MakeMKV
2) Load disc
3) Select the "Backup" icon (and make sure there is a checkmark next to "Decrypt")
4) Click on "Okay"
dahlberg123
#8 Post by dahlberg123 » Mon May 10, 2010 5:25 pm
setarip_old wrote:Mike is asking you to try using MakeMKV's "Backup" function, with "Decrypted" selected:
1) Start MakeMKV
2) Load disc
4) Click on "Okay"
Thanks, I'll do that and post my findings.
