Screener won't open
Gkohler
Screener won't open
Post by Gkohler » Sun Dec 11, 2016 8:46 pm
some of the new screeners have worked fine. but i just ran into a problem while trying to rip Arrival.
I tried cleaning it, but it keeps doing the same thing. hoping someone can help!
Thank you!
MakeMKV v1.10.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/garrettkohler/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GS23N SB03d" opened in OS access mode.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS01d" opened in OS access mode.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
DEBUG: Code 1 at YC2#{>EzExZ@=?:121263521
Title #0 with special attributes was skipped
OS device name: /dev/rdisk7
Current profile: DVD-ROM
Manufacturer: TSSTcorp
Product: BDDVDW SE-506AB
Revision: TS01
Serial number: R8L56GWCA002AR
Bus encryption flags: 1F
Highest AACS version: 58
Disc Information
Label: ARRIVAL
Timestamp: 2016-10-25 17:55:18
Data capacity: 6.22 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
danBoi2016
Re: Academy Screener won't open
Post by danBoi2016 » Sun Dec 11, 2016 11:26 pm
its COPY PROTECTED FOR A REASON LOL, u could allways post a pic of the disc so we can see if its real, is it dvd or bluray?
Lovely Rita
Post by Lovely Rita » Sun Dec 11, 2016 11:30 pm
Maybe the MPAA will send you a new copy. :lol:
Registered User :wink:
Buy MakeMKV
Gkohler
Post by Gkohler » Mon Dec 12, 2016 12:32 am
danBoi2016 wrote:its COPY PROTECTED FOR A REASON LOL, u could allways post a pic of the disc so we can see if its real, is it dvd or bluray?
DVD. I copy them for myself, to put on a hard drive. Just looking for a solution here.
Re: Screener won't open
Post by Woodstock » Mon Dec 12, 2016 2:51 am
Screener DVDs comes up every few months ago, and one of them was yours back in 2015. You tried manual extraction then, and it didn't help. Mike added something to combat their (then) new copy protection.
But there was some news items that the new screeners have had their copy protection updated AND a "finger print" burned into the disk that ties it to an individual. Not sure if Mike's done anything about that...
