This Application Version is too old??
mdrodge
Post by mdrodge »
I installed the last version about 1 weeks ago ish (not 60 days)
I got the message that the version is to old so i updated to the latest version..
I still got the same message so i uninstalled and reinstalled...
I still got the message so i uninstalled then rebooted then reinstalled.
It only gives two options "ok" or "enter code"
If it wants my money then that's ok but there is no link to be found anywhere so i am locked out until the issue is fixed (PROBABLY REQUIRING ANOTHER UPDATE)
Until that this program was working well but i still have about %50 of my DVD/Blu-ray's still to rip.
Can anyone offer advice if not a fix is required
Re: This Application Version is too old??
Post by d00zah »
Several other recent threads to the same effect...
IF you want to buy a license, open the app & select Help > Purchase
- OR -
see the following announcement for a temporary beta key:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
which will expire & require re-applying periodically.
Hope this helps.
mdrodge
Post by mdrodge »
can't open app due to this message but I'll use the link.
mdrodge
Post by mdrodge »
I'm in thanks.
8)
