MakeMKV 1.10.2 for Windows - Says it is outdated
drgreen
When I try to download the latest version, it won't let me open it because it says the version is outdated.
what up?
what up?
rlewandowski23
Re: MakeMKV 1.10.2 for Windows - Says it is outdated
Same for me! Please fix asap. I have dvds to rip
jalapeno
Same for me. Just downloaded today (windows version). Ran it once. Closed it. Reopened later and get this message:
"This application version is too old. Please download the latest version at / or enter a registration key to continue using the current version."
PS in the main window when I get that message it shows: MakeMKV v1.10.2 win(x64-release) started
Edit: found the answer. You need to past the registration key found here:
http://makemkv.com/forum2/viewtopic.php?f=5&t=1053
That worked for me.
That worked for me.
ericsson007
pacati
Same problem. I'd enter a registration key if I had one. Would buy the software if there was a way...
mmortal03
jalapeno
Not sure why my post disappeared. I had the same issue.
Under "news and announcements" the post titled "MakeMKV is free while in beta" has the key good thru jan 2017
tpiguet
yorgo
A key can be purchased here: www.makemkv.com/buypacati wrote:Same problem. I'd enter a registration key if I had one. Would buy the software if there was a way...
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
rlewandowski23
That worked - T-lAx41P60qUCpItEaWeTy4lU1PzJ7F3qIvKQxircspYn1lT9f9ubuvvghA6DJAnkAsjtpiguet wrote:go here yall
