The Story of O not pulling up correct playlist
birdman
#1 Post by birdman » Wed Dec 07, 2016 9:56 pm
The files pulled up are both 14GB files and neither could be saved, get TRACK FOLLOWING ERROR. The correct playlist (I opened the contents and found 00016.m2ts and it is 15GB) is not even being found. Tried adjusting the title search through a variety of intervals, nothing is working.
Story of O, Netflix N.A.
Debug:
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '882898944'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '882898944'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '882900992'
DEBUG: Code 1073741829 at l.=[)p[_HFpS#)=V;6:121262969
DEBUG: Code 100927744 at l.=[)p[_HFpS#)=V;6:121262969
DEBUG: Code 0 at Uqj@95l~5sd0]0 U<lCP:121263291
DEBUG: Code 0 at z:XU`$c@Jl!p?^EYch+6:121262302
DEBUG: Code 0 at Uqj@95l~5sd0]0 U<lCP:213130812
DEBUG: Code 431103 at Uqj@95l~5sd0]0 U<lCP:29393286
DEBUG: Code 0 at K}wjAYQ,p'<kFY]]d6(,W:29398967
Failed to save title 1 to file /Volumes/Seagate Bac/#movies/dvd/The_Story_of_O_t01.mkv
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '882671616'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '882671616'
DEBUG: Code 100860416 at l.=[)p[_HFpS#)=V;6:121262969
DEBUG: Code 430992 at Uqj@95l~5sd0]0 U<lCP:29393286
Failed to save title 2 to file /Volumes/Seagate Bac/#movies/dvd/The_Story_of_O_t02.mkv
8 titles saved, 2 failed
Re: The Story of O not pulling up correct playlist
#2 Post by Woodstock » Thu Dec 08, 2016 12:07 am
See http://makemkv.com/forum2/viewtopic.php?f=8&t=14330
Mike has said if MakeMKV comes up with a wrong guess, he wanted the information requested in this topic to help refine the program.
birdman
#3 Post by birdman » Thu Dec 08, 2016 7:20 pm
Awesome, will do what is asked. Thank you for the response.
birdman
#4 Post by birdman » Fri Dec 09, 2016 1:46 am
Unable to backup the disc.
MakeMKV v1.10.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/jonathan/MakeMKV_log_1.txt
Optical drive "BD-RE MATSHITA BD-MLT UJ267AM 1.00d" opened in OS access mode.
Backing up disc into folder "/Volumes/Seagate Bac/#movies/dvd/backup/BDROM"
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '890105856'
DEBUG: Code 0 at 6BX6bp@II@V&n=h}|>f:213134354
DEBUG: Code 0 at 6BX6bp@II@V&n=h}|>f:29397564
DEBUG: Code 0 at 3nD2->a# 4k0phKev8l5:121265108
Backup failed
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '893448192'
Backup failed
#5 Post by Woodstock » Fri Dec 09, 2016 2:58 am
Track following errors are caused by badly manufactured disks, scratches, dirty disks, and defects in the drive, in no particular order.
Dirt (often fingerprints) is easily dealt with, cleaning with a soft, damp cloth. Scratches can be small enough to be almost invisible, but still cause problems for the laser. Badly manufactured disks can only be dealt with by getting the disk replaced.
Drive failures... well, can you read other disks?
birdman
#6 Post by birdman » Sat Dec 10, 2016 12:19 am
Upon closer examination, it is badly manufactured. Strange lines running the width of the disc and making sharp turns - looks like if you break a CD/DVD.
As long as they're not bad.
