Jason Bourne
MattNA
Jason Bourne
Post by MattNA »
Just got the new Jason Bourne (Bluray) movie and it never gets past the "Opening DVD part"
MakeMKV v1.10.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Matt/MakeMKV_log_2.txt
Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_111\bin
DEBUG: Code 5 at Z-nsZ0--$i ]=!Z.X>:121263866
Failed to execute external program 'java' from location 'C:\Program Files (x86)\Java\jre1.8.0_111\bin'
DEBUG: Code 57838 at Phfm@gV#l/rl6f}$uB:213136723
New decryption?
Re: Jason Bourne
No, a failure to load your Java Runtime Environment (JRE) from the location your system says it is at. Could be a permissions issue, or it could be a missing file.
MattNA
Re: Jason Bourne
Post by MattNA »
You guys are quick!
MattNA
Re: Jason Bourne
Post by MattNA »
My best guess is I must have a defective disc. Java is updated to the latest version.
VLC won't play the Blu-Ray either
core error: open of `dvd:///G:\' failed
logger info: VLC media player - 2.2.4 Weatherwax
logger info: Copyright © 1996-2016 the VideoLAN team
logger info: Warning: if you cannot access the GUI anymore, open a command-line window, go to the directory where you installed VLC and run "vlc -I qt"
logger info: using logger.
logger error: error opening logfile `vlc-log.txt': Permission denied
core error: no suitable interface module
core error: interface "logger,none" initialization failed
I have the Blu-ray player (G) open in a browser but I have no idea which file to look for.
Get another I guess?
Ahhh, The movie was pretty low in the ratings anyway. lol
MattNA
Re: Jason Bourne
Post by MattNA »
Blu-ray error:
This Blu-ray Disc needs a library for AACS decoding, and your system does not have it.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///G:/'. Check the log for details.
More VLC info if that helps
I'm doing a search for "AACS decoding" for S&G's
Re: Jason Bourne
Follow the procedures in the FAQ in my signature to enable debug logging. Without more information from the log, it's hard to guess what is going on.
If we are dealing with a new version of AACS or BD+, the log will have more information, and MakeMKV would have created dump files in its data directory for Mike to look at.
MattNA
Re: Jason Bourne
Post by MattNA »
Debug log started at Wed Dec 07 21:38:05 2016 , written by MakeMKV v1.10.2 win(x64-release)
001005:0000 MakeMKV v1.10.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Matt/MakeMKV_log.txt
003344:0000 Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_111\bin
001003:0020 DEBUG: Code 5 at Z-nsZ0--$i ]=!Z.X>:121263866
004041:0000 Failed to execute external program 'java' from location 'C:\Program Files (x86)\Java\jre1.8.0_111\bin'
001003:0020 DEBUG: Code 52258 at Phfm@gV#l/rl6f}$uB:213136723
DEBUG: Code 0 at Phfm@gV#l/rl6f}$uB:121262003
DEBUG: Code 0 at Phfm@gV#l/rl6f}$uB:121261451
I have already started a return/exchange with this Blu-ray. Let me know if I did the right thing, if you don't mind.
Thanks again.
MattNA
Re: Jason Bourne
Post by MattNA »
Received another copy, still no luck.
Followed the instructions here, restarted, no luck.
https://www.easefab.com/tutorial/play-b ... layer.html
I'm going to try this again sometime. Honestly, I was cutting corners.
MKV debug log
Debug log started at Sat Dec 10 01:29:21 2016 , written by MakeMKV v1.10.2 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as C:\Users\Matt/MakeMKV_log_1.txt
001003:0020 DEBUG: Code 49270 at Phfm@gV#l/rl6f}$uB:213136723
Any help is appreciated.
MattNA
Re: Jason Bourne
Post by MattNA »
Also tried uninstalling Java via Javara and reinstalling Java. Confirmed java than restarted.
That didn't work either
Debug log started at Sat Dec 10 04:19:41 2016 , written by MakeMKV v1.10.2 win(x64-release)
001003:0020 DEBUG: Code 51759 at Phfm@gV#l/rl6f}$uB:213136723
MattNA
Re: Jason Bourne
Post by MattNA »
Anybody?
MattNA
Re: Jason Bourne
Post by MattNA »
One guess I have is MakeMKV doesn't know the path/address to the Jave bin?
How can this be checked and edited if possible?
MattNA
Re: Jason Bourne
Post by MattNA »
MattNA wrote:One guess I have is MakeMKV doesn't know the path/address to the Jave bin?
Nevermind, found it! Just had to look for it.
I'm still stumped if anybody else can help, that would be great.
Free red stapler (or cookie) to somebody with the answer.
MattNA
Re: Jason Bourne
Post by MattNA »
Executed a command line:
C:/Program Files (x86)/Java/jre1.8.0_111/bin%CommonProgramFiles%\Microsoft Shared\Windows Live;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:/Program Files (x86)/Java/jre1.8.0_111/bin
Still N/G
Supposedly this command line will redirect the path to where The java bin file is.
Does anybody know if I'm experiencing a java runtime error?
Debug log started at Tue Dec 13 23:26:54 2016 , written by MakeMKV v1.10.3 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.10.3 win(x64-release) started
Application exited at Tue Dec 13 23:41:08 2016
MattNA
Re: Jason Bourne
Post by MattNA »
I will just assume this is a "streetlock" issue.
I do not get an error listed in yorgo thread but my error code does involve Java and AACS.
The one thing that doesn't make sense is the BR will play in my BR player but without the DTSX soundtrack.
DTSX is listed as the soundtrack but my AVR confirms what my ears are hearing. A regular DTS soundtrack.
A competitor's ripping trial software will make an MKV 2.0 preview.
