Blu-Ray to MKV Choppy Playback
TopGun2010
Re: Blu-Ray to MKV Choppy Playback
#16 Post by TopGun2010 » Wed Mar 11, 2009 9:32 am
You can download the new version.
context
#17 Post by context » Thu Mar 12, 2009 10:29 pm
@mike&TopGun2010: Attention - I can confirm now :arrow: Still choppy playback. Bugfix didn't work!
TopGun2010
#18 Post by TopGun2010 » Fri Mar 13, 2009 5:47 am
I have very good playback on Popcorn Hour A-110 and choppy plaback on VLC.
context
#19 Post by context » Fri Mar 13, 2009 11:03 am
i can definitely say the playback is still choppy.
killamac
#20 Post by killamac » Fri Mar 13, 2009 2:38 pm
having still the same problem
jketch
#21 Post by jketch » Fri Mar 13, 2009 8:19 pm
I'm experiencing the same thing. The tsmuxer workaround still works though.
context
#22 Post by context » Sat Mar 14, 2009 2:26 pm
yeah, tsmuxer/mkvmerger works like a charm :P
jbennett
#23 Post by jbennett » Wed Apr 08, 2009 10:21 pm
FYI, I'm still seeing this "choppy playback" problem with VC-1 encoded discs under MakeMKV v1.4.0 beta. Do you know yet what the issue is, or have any plans or timetable for a fix?
--John
#24 Post by mike admin » Thu Apr 09, 2009 8:10 am
apparently the error was fixed only partially. we are tring to get it corrected in the next version.
#25 Post by mike admin » Mon Apr 13, 2009 8:32 am
This is finally corrected in 1.4.1. All VC-1 titles should play correctly from now on.
dvdevil
#26 Post by dvdevil » Mon Apr 13, 2009 10:31 am
Yes vc-1 plays fine now thanks
cornbread
#27 Post by cornbread » Mon Apr 13, 2009 5:30 pm
Hi, where can I download this new version, 1.4.2? Would love to try it. Great app so far!
#28 Post by mike admin » Tue Apr 14, 2009 7:40 am
cornbread wrote:Hi, where can I download this new version, 1.4.2? Would love to try it. Great app so far!
It should have been 1.4.1. My mistake.
jbennett
#29 Post by jbennett » Tue Apr 14, 2009 10:30 pm
mike admin wrote:This is finally corrected in 1.4.1. All VC-1 titles should play correctly from now on.
Confirmed, 1.4.1 fixed the problems I was previously seeing on my VC-1 titles. Thanks!
--John
ChaosFusion
#30 Post by ChaosFusion » Fri May 22, 2009 9:18 am
Hi All, I believe there is still a issue with Blu-Ray ripped movies, I have just ripped 4 movies at home, and two worked & the other two gives me choppy playback 100% of the time. I have ripped them 3 times with the same output.
If I play all the movies in the normal Blu-Ray ripped format off the hard-drive, it all works perfect, when I convert to MKV(1.4.2), two of the movies become very choppy on the playback ?
One thing I also noticed, the movies that worked, seam to be running thru my video card (ATI HD 3850, 512mb Ram) when I use Media Player Classic (v1.2.908.0 in EVR mode, I get very low CPU usage), the other two I get very high CPU and choppy playback ?
I have tried all the normal. Change video drivers back about 10 versions, but I think the key is in the playback high CPU issue.. any ideas ?
Casino Royal works perfect.
Video : MPEG4 (H264) 1920x1080 23.98fps
Audio : Dolby AC3 48000HZ 6ch
Quantum of Solace, very choppy.
Audio : DTS 48000HZ 6ch
Transformers works perfect.
Black Hawk Down , very choppy.
Video : MPEG2 1920x1080 23.98fps
My Specs : 2 x Xeon 2.81GHz with Hypertask (Quad CPU’s), RAM 2GB
Windows Vista Ultimate 32bit, running windows Media Center
4 SATA HD’s, total 3TB. Video Card : ATI 3850 HD, 512k Ram
