Blu-Ray to MKV Choppy Playback
TopGun2010
Re: Blu-Ray to MKV Choppy Playback
You can download the new version.
context
@mike&TopGun2010: Attention - I can confirm now
Still choppy playback. Bugfix didn't work!
TopGun2010
I have very good playback on Popcorn Hour A-110 and choppy plaback on VLC.
context
i can definitely say the playback is still choppy.
killamac
having still the same problem
jketch
I'm experiencing the same thing. The tsmuxer workaround still works though.
context
yeah, tsmuxer/mkvmerger works like a charm
jbennett
FYI, I'm still seeing this "choppy playback" problem with VC-1 encoded discs under MakeMKV v1.4.0 beta. Do you know yet what the issue is, or have any plans or timetable for a fix?
--John
--John
apparently the error was fixed only partially. we are tring to get it corrected in the next version.
This is finally corrected in 1.4.1. All VC-1 titles should play correctly from now on.
dvdevil
Yes vc-1 plays fine now thanks
cornbread
Hi, where can I download this new version, 1.4.2? Would love to try it. Great app so far!
It should have been 1.4.1. My mistake.cornbread wrote:Hi, where can I download this new version, 1.4.2? Would love to try it. Great app so far!
jbennett
Confirmed, 1.4.1 fixed the problems I was previously seeing on my VC-1 titles. Thanks!mike admin wrote:This is finally corrected in 1.4.1. All VC-1 titles should play correctly from now on.
--John
ChaosFusion
Hi All, I believe there is still a issue with Blu-Ray ripped movies, I have just ripped 4 movies at home, and two worked & the other two gives me choppy playback 100% of the time. I have ripped them 3 times with the same output.
If I play all the movies in the normal Blu-Ray ripped format off the hard-drive, it all works perfect, when I convert to MKV(1.4.2), two of the movies become very choppy on the playback ?
One thing I also noticed, the movies that worked, seam to be running thru my video card (ATI HD 3850, 512mb Ram) when I use Media Player Classic (v1.2.908.0 in EVR mode, I get very low CPU usage), the other two I get very high CPU and choppy playback ?
I have tried all the normal. Change video drivers back about 10 versions, but I think the key is in the playback high CPU issue.. any ideas ?
Casino Royal works perfect.
Video : MPEG4 (H264) 1920x1080 23.98fps
Audio : Dolby AC3 48000HZ 6ch
Quantum of Solace, very choppy.
Audio : DTS 48000HZ 6ch
Transformers works perfect.
Black Hawk Down , very choppy.
Video : MPEG2 1920x1080 23.98fps
My Specs : 2 x Xeon 2.81GHz with Hypertask (Quad CPU’s), RAM 2GB
Windows Vista Ultimate 32bit, running windows Media Center
4 SATA HD’s, total 3TB. Video Card : ATI 3850 HD, 512k Ram
