Loaded up MakeMKV today (and was forced to update again - really annoying), but got through all that and started to try to rip a disc as normal. it progressed part way through the rip and then failed with an error similar to... Error 'OS error - A non close operation has been requested of a file object with a delete pending' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '432537600'
I tried again but got the same results. I then tried another disc (different film) but got the same error (just different offset location). I updated the firmware on my blu-ray drive and tried again... same results. I then tried to rip the last disc that I had successfully ripped, but got the same error. Is there a problem with the current version of MakeMKV? Is there any way we can download a previous version to try and see if it works?
Here is the full error log from the last disc (the one that DID work previously)....
MakeMKV v1.10.2 win(x64-release) started
File 00800.mpls was added as title #0
File 00200.mpls was added as title #1
File 00201.mpls was added as title #2
Title #00020.mpls has length of 175 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00090.mpls has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00210.mpls has length of 472 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00091.mpls has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00006.m2ts has length of 29 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00029.m2ts has length of 87 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00030.m2ts has length of 87 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00135.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00136.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00137.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00139.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00140.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00141.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00145.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00146.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00303.m2ts has length of 251 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00304.m2ts has length of 267 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00305.m2ts has length of 242 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00306.m2ts has length of 357 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00307.m2ts has length of 33 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00308.m2ts has length of 52 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00309.m2ts has length of 29 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00310.m2ts has length of 173 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00138.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00142.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00312.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00314.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00315.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00316.m2ts has length of 123 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00317.m2ts has length of 130 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00318.m2ts has length of 32 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/MARVEL'S_CAPTAIN_AMERICA_CIVIL_WAR_-_BLU-RAY
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '432537600'
Failed to save title 0 to file D:/Video/MARVEL'S_CAPTAIN_AMERICA_CIVIL_WAR_-_BLU-RAY/MARVEL'S_CAPTAIN_AMERICA_CIVIL_WAR_-_BLU-RAY_t00.mkv
0 titles saved, 1 failed
Problems ripping multiple discs - file close operation...
Re: Problems ripping multiple discs - file close operation..
Further, when this error occurs, MakeMKV won't do anything else. If I hit the button to try again, the same set of errors comes up again, even though the disc never actually spins up. I have to close MakeMKV completely and restart it to try to get it to do anything again.
Seems to be working now. I rebooted the computer and power cycled the blu ray drive leaving everything unplugged for over 30 seconds. After rebooting everything, I was able to successfully rip a few discs again.
