Not able to copy BluRay with AACS v48
rfruffy
Post by rfruffy »
Unfortunately I cannot copy a BluRay with AACS v48 to my computer.
About 100 Discs I own, I have already copied to my NAS. I did not have a look at the AACS Version so far,
but support for AACS v48 was given by makemkv already in 2014.
Does anyone have an idea, how I can solve this problem?
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BH16NS40
Revision: 1.03
Serienummer: K9KF1795623
Firmware-Datum: 2114-03-26 11:15:
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 58
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '960294912'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '960294912'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '960299008'
DEBUG: Code 3221225628 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 100864261 at 0*u53V?r+$wd$Pq.aI:121262969
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:121263291
DEBUG: Code 0 at zjJ4tTzD?zIb*hXiSG\):121262302
DEBUG: Code 0 at 8=h{tZTtt133Ig!gb;mX:213130812
DEBUG: Code 468894 at 8=h{tZTtt133Ig!gb;mX:29393286
DEBUG: Code 0 at T:}L'Aj<w&w(~v+!IEKR(:29398967
Failed to save title 8 to file G:/FilmeG/Die Bestimmung 1 - Divergent/Die_Bestimmung_t08.mkv
0 titles saved, 1 failed
rfruffy
Re: Not able to copy BluRay with AACS v48
Post by rfruffy »
I just checked that I already copied discs with AACS v51.
So may be the disc is defect ?
yorgo
Post by yorgo »
This does not appear to be an encryption issue but rather a problem with the disc, or possibly the drive. Please see this post: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
BTW, what version of MakeMKV are you on?
rfruffy
Post by rfruffy »
I'm on the actual Version 1.10.2. x64.
Yeah seems to be the disc indeed.. I tried several other ones and it worked again without problems.
Unfortunately, my drive does not have any new firmware, so it seems that disks newer as AASC v58 might not work again in the future...
If your drive gets an AACS revocation update, it will stop working with ANY version of AACS, until the application using the revoked key gets a new key. So if it were a revocation issue, you would only be able to rip DVDs in that drive until MakeMKV was updated.
But most AACS changes do not revoke playback keys, apparently; They just change the encryption key. And MakeMKV 1.10.2 know about all the keys through AACS v62, so decryption should not be an issue, so long as the drive can read the disk without error. Yours is saying it can't, and that the drive is reporting "not ready" at times.
Is it an external or internal drive?
rfruffy
Post by rfruffy »
It is an internal drive and all discs were read before this one :-)
