Major Screen Tearing on Blu Rays since last update
Spazz Brown
Post by Spazz Brown » Mon Nov 28, 2016 9:09 pm
Anyone else experiencing major screen tearing/distortion on backing up BR's since the last patch? Seems to be happening on scenes that have a lot going on and I'm trying to figure out if its makemkv, the new BR's, or my BR drive. So far I have experienced this on both the GhostBusters (2016) and Independence Day Resurgence.
I received no errors that I'm aware of during recording and both discs were in good shape as far as I could tell.
Prior to the new update I had no issues with backing up BR's
Re: Major Screen Tearing on Blu Rays since last update
Post by Woodstock » Mon Nov 28, 2016 10:24 pm
When you ripped the disks, did you get any messages about "No FUTs"?
What you are describing sounds like BD+ encryption not being removed.
Check your MakeMKV data directory to see if you have some BD dump files awaiting transfer to svq@makemkv.com . The location of the directory is found in Preferences->General.
Spazz Brown
Post by Spazz Brown » Tue Nov 29, 2016 3:07 am
Sounds good I'll check it out tomorrow and post my findings thank you.
