Tries to rip using two diferent computers.
Tried to play mkv using two different versions of XBMC on two different computers.
The results are always the same. There is audio but no video.
Attached is the log file.
Journey to the Edge of the Universe (Documentary) Blue-Ray
tommck
Lovely Rita
Re: Journey to the Edge of the Universe (Documentary) Blue-R
Try playing it with VLC, and see what tracks are available (Ctrl-I in most versions of VLC).
If your software still announces itself as "XBMC", look at upgrading to a current version... It is now called "Kodi".
tommck
Sorry. Cannot attach the log file. Getting a message that board attachment quota has been reached. Must have missed that message when I originally posted.
Anyway, thanks...I'll try installing and playing with Kodi on a test PC. I cannot install Kodi on my video PC because I will loose the ability to edit (make corrections to) the meta-data. So if it works with Kodi I am out of luck anyway. Not a big deal.
No need to "attach" logs - they can be put in the message body if they're less than about 50K in size. Just click on the "Code" button when editing the message, and past the text between the tags that will appear.
