Can't read Finding Dory
waterbaby64
Post by waterbaby64 » Fri Nov 25, 2016 9:04 pm
I've tried two different PCs, and even got a new Blu-Ray drive and no matter what I do, the program hangs.
I tried the 3 different mpls source files: 801, 802, 800 (not sure which one is right). I always open it up and select DTS-HD MA Surround.
Whenever it starts,
1. It finishes "Analyzing seamless segments"
2. Starts to save titles
3. Then reports "The source file '/BDMV/STREAM/00411.m2ts' is corrupt or invalid at offset 244051968'
4. Hash check failed for 0411.m2ts at offset 244180992
5. Then reports "The source file '/BDMV/STREAM/00411.m2ts' is corrupt or invalid at offset 244119552''
At this point MakeMKV fails.
Running Windows 10 Pro Insider Preview Build 14971.rs_prerelease.161111-1700, MakeMKV v1.10.2
Lovely Rita
Re: Can't read Finding Dory
Post by Lovely Rita » Fri Nov 25, 2016 11:27 pm
No problems, here, with Finding Dory.
Sounds like a bad disc to me but you may want to peruse this post for further tips and tricks.
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=15279
BTW - the correct (English) mpls is 800, as it normally is for Disney discs.
Registered User :wink:
Buy MakeMKV
waterbaby64
Post by waterbaby64 » Sat Nov 26, 2016 4:24 pm
Lovely Rita wrote:No problems, here, with Finding Dory.
Thanks Rita. I should have stated that I tried those suggestions. It looks like you were correct. It was the disk. I went and got another one and it worked just fine.
shepx13
Post by shepx13 » Fri Dec 02, 2016 4:22 am
I got it working, I didn't have the stereo track selected.
