Green Room multiple playlists
Uatu.
Re: Green Room multiple playlists
#16 Post by Uatu. » Sat Jul 16, 2016 1:06 pm
Anyone know what file to use for the Canadian version?
ingen1ous
#17 Post by ingen1ous » Thu Sep 08, 2016 12:52 am
Does anyone know the correct playlist for the following UPC: 031398245605
It's the standard U.S. retail version. I don't have playlist 764 on mine.
carboranadum
#18 Post by carboranadum » Wed Sep 21, 2016 7:09 pm
Anyone know the correct playlist for the netflix version?
brellyn
#19 Post by brellyn » Wed Nov 23, 2016 8:02 pm
carboranadum wrote:Anyone know the correct playlist for the netflix version?
It appears that 00764.mpls is also correct for Netflix. You won't see it in the list however. It's located at the top as Green Room - 16 chapter(s), 18.1 GB (FPL_MainFeature). Click on it and you'll get the following title info.
Title information
Comment: FPL_MainFeature
Source file name: 00764.mpls
Duration: 1:35:01
Chapters count: 16
Segment count: 20
Segment map: 506,512,520,519,507,509,513,508,517,516,511,514,515,502,505,518,501,504,503,510
File name: Green_Room_t02.mkv
I'm going to test it now, but I think we have a winner.
brellyn
#20 Post by brellyn » Fri Nov 25, 2016 2:07 am
brellyn wrote:It appears that 00764.mpls is also correct for Netflix.
Confirmed. Watched the 00764 rip and the BluRay in two windows and they matched.
Matthew_ Cinema
#21 Post by Matthew_ Cinema » Sun Aug 27, 2017 6:16 am
Uatu. wrote:Anyone know what file to use for the Canadian version?
If anyone is looking for the correct MPLS for the Canadian version, I found it! The Canadian MPLS is 00918. It took a LOT of legwork to sift through it all, as there had to be well over 200 playlists (I didn't count). As for the exact version/provider, I got mine used from a rental shop. I hope this helps!
Title information
Name: Green Room (English)
Source file name: 00918.mpls(1)
Duration: 1:35:01
Chapters count: 15
Segment count: 20
Segment map: 519,513,509,517,504,501,508,515,516,511,2857,507,520,512,510,503,514,506,518,502
File name: Green_Room_t275.mkv
GaryGygax
#22 Post by GaryGygax » Tue Jul 17, 2018 4:25 pm
ingen1ous wrote:Does anyone know the correct playlist for the following UPC: 031398245605
You ever figure this one out? I have the same UPC (bought at store) and I DO have 764?
zzeedd56
#23 Post by zzeedd56 » Tue Jul 21, 2020 12:10 am
mine looks like this
green rm.JPG (19.97 KiB) Viewed 17081 times
