First time user. For some reason I don't seem to be capturing/converting the main movie file. Just all the extras. Any idea why?
Not capturing movie file
yorgo
Re: Not capturing movie file
Need more info such as DVD or Blu-Ray? Do you see an error message during ripping?
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
And are you sure you got the "main feature disk", and not the "extras disk"?
vedivan
Yorgo - Sorry. DVD. No error. Seems to work as it should but only converts small files.
Woodstock - Yes, I'm sure. Launch disk with WMP, and movie is on there.
yorgo
What is the movie/disc? Can you post a screenshot of the MakeMKV main menu once the disc has opened?
