Mechanic: Resurrection-Correct playlist?
bigga747
brownchristopher1969
Re: Mechanic: Resurrection-Correct playlist?
I've noticed once someone has found the correct segment map, the mpls does't really matter. In this case segment map- Segment map: 510,518,503,506,519,502,501,508,507,513,516,515,504,511,514,517,509,505,512,520 is correct. I recommend using VLC Player & AnyDVD when trying to work out the correct segment order. Run AnyDVD, let it scan the disc, then go into the disc under BDMV & then stream. Inside here copy all "500" series m2ts files to your computer (usually 500-515 or 500-520). After this you can remove the disc. I usually play it on a player & watch what I need to see on TV, meanwhile use VLC Player or any player that can play m2ts files. Then I like to move the files on my desktop in a line, left to right until I've worked out the segment order. Then you MUST exit AnyDVD completely, re-insert the disc and scroll thru to find the correct segment sequence & the fun task of un-checking all titles that are not the correct playlist. Hope this helps!
LG-BDNU40
Last week I installed Java as I read it's used with makemkv to point to the correct playlist. Well it labeled one track as "FPL_MainFeature" as below:
Name: Mechanic: Resurrection (English)
Comment: FPL_MainFeature
Source file name: 00393.mpls
Duration: 1:38:38
Chapters count: 16
Segment count: 20
File name: Mechanic_Resurrection_t00.mkv
Shame Java can't re-create the DTS-HD soundtrack that PussyGate removes from the Redbox rentals, no?
Duration: 1:38:38
Chapters count: 16
Segment count: 20
outdoorguy568
If you look under "Status" in ANY it will give you the "Java BD protection good playlists" number. No need for VLC.brownchristopher1969 wrote:I've noticed once someone has found the correct segment map, the mpls does't really matter. In this case segment map- Segment map: 510,518,503,506,519,502,501,508,507,513,516,515,504,511,514,517,509,505,512,520 is correct. I recommend using VLC Player & AnyDVD when trying to work out the correct segment order. Run AnyDVD, let it scan the disc, then go into the disc under BDMV & then stream. Inside here copy all "500" series m2ts files to your computer (usually 500-515 or 500-520). After this you can remove the disc. I usually play it on a player & watch what I need to see on TV, meanwhile use VLC Player or any player that can play m2ts files. Then I like to move the files on my desktop in a line, left to right until I've worked out the segment order. Then you MUST exit AnyDVD completely, re-insert the disc and scroll thru to find the correct segment sequence & the fun task of un-checking all titles that are not the correct playlist. Hope this helps!
gereral1
Power DVD has updated mpls.DLL. Try setting .m2ts filter and watch movie at 16x speed. Write down the segment map. Does it call the correct m2ts files? If not then the process monitor no longer works with newer disks. Time to find other methods or go back to using redfox or old Slysoft version with bdedit to quickly elimates mpls files while accessing segments in mpccswackha wrote:For US Redbox I also got 554 using procmon. Why does this not work. Am I not using procmon properly?
Title information
Source file name: 00554.mpls
Duration: 1:38:38
Chapters count: 16
Segment count: 20
Segment map: 510,503,518,506,519,507,515,516,502,501,513,508,504,511,517,514,509,505,512,520
File name: Mechanic_Resurrection_t222.mkv
PS I attempted to attach the PML file but it hard issues uploading for some reason.....
Zenophobe
My retail disk shows this for the FPL_MainFeature:LG-BDNU40 wrote:Last week I installed Java as I read it's used with makemkv to point to the correct playlist. Well it labeled one track as "FPL_MainFeature" as below:
Duration: 1:38:38
Chapters count: 16
Segment count: 20
Title information
Source file name: 00466.mpls
Duration: 1:38:38
Chapters count: 16
Segment count: 20
Segment map: 515,516,505,504,518,520,507,510,517,501,509,513,503,512,511,519,514,502,506,508
Usually you can look at the duration count but even that stays the same. I don't seem to have what others have described as playlists or Source File Name.
kevonator
Is 393 correct for Netflix in US?
ThirdDraft
I have had no luck with this one, from the US Netflix disc. Almost at the end of the rip I get the following and it just goes on and on.kevonator wrote:Is 393 correct for Netflix in US?
The source file '/BDMV/STREAM/00520.m2ts' is corrupt or invalid at offset 7311783936, attempting to work around
troyBORG
I bought the 4k UHD Version, and the 1080p BluRay in it has:
Screenshot: http://imgur.com/uxT4fgz
Title information
Duration: 1:38:38
Chapters count: 16
Segment count: 20
File name: Mechanic_Resurrection_t04.mkv
gereral1
FPL_MainFeature is thistill accurate in makemkv or is it hit and miss?
ThirdDraft
On my second attempt at this I shipped back the disc that was giving me the problem mentioned in my last post. Received a replacement and voila! Ripped 393 and looks like it ripped without any problems and follows the segments in proper order (NetFlix Rental)...kevonator wrote:Is 393 correct for Netflix in US?
Title information
Duration: 1:38:38
Chapters count: 16
Segment count: 20
File name: Mechanic_Resurrection_t151.mkv
thors
I do not want this how do I stop from getting 50.00 on my credit card for blueray
If you want to cancel the order for a permanent key, you'll have to contact Mike directly. That would be via email at support@makemkv.com .
xbmcuser
Duration: 1:38:38
Chapters count: 16
Segment count: 20
FYI See my post:
viewtopic.php?f=8&t=9959#p42657
Reposting Here:
Researching this it seems the best/fastest way to find the correct segment map is to first backup the entire disc, which should be of normal size. Then knowing you need to work with a certain subset of segments your job is to now figure out their correct order, which the superset can be found here: BDMV/STREAM. You should be able to find each segment's starting point and length by referencing the movie.
It is somewhat tedious but using simple time math you can figure out the correct mapping faster than real time of the movie.
Duration: 1:38:38
Chapters count: 16
Segment count: 20
FYI See my post:
Reposting Here:
MakOwner
I have a Blu-Ray + DVD combo from The Movie Trading Company.
UPC 31398 25290 0 80
Not a single one of the 405 potential output files has a segment map that begins with 510.
Anyone have a hint as to which one may correct?
