Hell or High Water-Correct playlist?
anyone knows? thanks!
Re: Hell or High Water-Correct playlist?
Rental or purchase? Where rented or where purchased? What nationality/region?
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
US retailyorgo wrote:Rental or purchase? Where rented or where purchased? What nationality/region?
Title information
Name: Hell or High Water
Source file name: 00634.mpls
Duration: 1:42:15
Chapters count: 16
Segment count: 20
Segment map: 508,511,509,518,516,505,506,515,517,500,504,513,507,512,514,503,501,519,510,502
File name: Hell_or_High_Water_t176.mkv
Duration: 1:42:15
Chapters count: 16
Segment count: 20
Does anyone have the correct MPLS for the RedBox version?
I have RedBox but it does not have a 634 .mpls
US RB edition
Source file name: 00825.mpls
Duration: 1:42:15
Chapters count: 16
Segment count: 21
Segment map: 505,520,500,510,501,518,513,516,514,519,508,509,502,511,517,515,507,506,512,503,504
File name: Hell_or_High_Water_t196.mkv
Duration: 1:42:15
Chapters count: 16
Segment count: 21
ANY says 865 for RB.... but I can't find the 865 mpls.
I used MKV to back up the RB version to sort through segments. Using BDInfo, both vh5150's posted 00825.mpls and 00865.mpls listed are using same segment order.outdoorguy568 wrote:ANY says 865 for RB.... but I can't find the 865 mpls.
Interesting as BD-Java not displayed for correct playlist and 00865.mpls not displayed in original MKV scan. i got lots to learn...
AnyDVD sucks, as I was an original lifetime member, so will never support them again. Makemkv has been moving along nicely so will support them after this holidays crush.
Not to hijack the topic but to be clear; AnyDVD does not suck. It's unfortunate what happened with Slysoft, glad to see the devs decided to continue with the project and formed RedFox. I use it all the time for de-encrypting and finding correct playlists.LG-BDNU40 wrote: AnyDVD sucks, as I was an original lifetime member, so will never support them again. Makemkv has been moving along nicely so will support them after this holidays crush.
Anyone know if Netflix and RB version are the same playlist?
Netflix
Title information
Duration: 1:42:15
Chapters count: 16
Segment count: 21
Title information
Duration: 1:42:15
Chapters count: 16
Segment count: 21
The RB version you're referring to must be BD as it's 18.8GB.
Any idea for DVD?
There are two options...one is slightly longer than the other with different segment maps but the same number of chapters and file sizes. US version.
Any idea for DVD?
Thank you so much for this info!!xbmcuser wrote:Netflix
Title information
Duration: 1:42:15
Chapters count: 16
Segment count: 21
mpls: 825 is correct for Netflix US copy
