Star Wars a New Hope Has a fatal Error Backing up
csdonnell
Post by csdonnell »
Many of these and then it fails. The disk seems to be fine.
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15072983040, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073542144, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073548288, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073554432, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073560576, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073566720, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073597440, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15073867776, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15074193408, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15074260992, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15076159488, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15076749312, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15076816896, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15078715392, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15078979584, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15078998016, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15079004160, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15079010304, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15079016448, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15081861120, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15082162176, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15082168320, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15082180608, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15082186752, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15082450944, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15082518528, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15083108352, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15083440128, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15083470848, attempting to work around
The source file '/BDMV/STREAM/00301.m2ts' is corrupt or invalid at offset 15083476992, attempting to work around
Re: Star Wars a New Hope Has a fatal Error Backing up
Clean the disk with a damp, soft cloth and try again. Your drive is having issues reading the disk, and having to retry many times to get a clean read of parts of it.
csdonnell
Post by csdonnell »
Sorry guys my bad. It was a combination of network and dirty blu ray issues. I had cleaned the disk prior but I guess I missed a spot. Anyway ignore this post. Sorry again.
