DVD Rip Fails
jacki
DVD Rip Fails
Post by jacki »
This disc fails to open. Does anyone have any thoughts on what I'm doing wrong?
FYI, Handbrake sees no valid source for this disc.
MakeMKV v1.10.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/~~~~~~/MakeMKV_log.txt
Optical drive "BD-RE MATSHITA BD-MLT UJ265 1003d" opened in OS access mode.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
DEBUG: Code 1 at YC2#{>EzExZ@=?:121263521
DEBUG: Code 2 at YC2#{>EzExZ@=?:121263521
Title #0 with special attributes was skipped
Title #1 with special attributes was skipped
Re: DVD Rip Fails
We're going to have to wait for Mike to decode the debug strings, but I'd recommend following the procedure listed in the FAQ in my signature. Sending the files requested to support@makemkv.com is the fastest way to have Mike look them over.
jacki
Re: DVD Rip Fails
Post by jacki »
Thanks! Following the protocol as requested.
RusefSandi
Re: DVD Rip Fails
Post by RusefSandi »
Woodstock wrote:We're going to have to wait for Mike to decode the debug strings, but I'd recommend following the procedure listed in the FAQ in my signature. Sending the files requested to support@makemkv.com is the fastest way to have Mike look them over.
Thanks for this tips.
