Manual Mode for Dummies
Tom Swyft
Post by Tom Swyft »
I'm trying to use manual mode, but don't know how to access it.
I've read this: http://makemkv.com/manualdvd/ which explains how manual mode works, but not how to turn it on.
I've read this: http://www.makemkv.com/forum2/viewtopic ... 005#p51240 which say
Launch MakeMKV, choose the right drive, and tick the "Open DVD manually" checkbox
But I don't see any checkbox on my GUI.
Can someone please explain how to access manual mode?
Many thanks, many apologies if I'm missing something completely obvious.
Re: Manual Mode for Dummies
Are you trying to open a DVD or a Bluray?
The box won't exist if the disk isn't a DVD.
Backup mode only exists for Bluray, and Manual mode only exists for DVD.
Tom Swyft
Post by Tom Swyft »
Yes, it's a DVD.
Type: DVD
Protection: CSS / CPPM
Disc type: DVD-ROM
Data Capacity: 5.80 Gb
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
OK, I've confirmed the box appears for DVDs in the Windows GUI; someone else with a Mac will have to say whether it shows up for him or her on the Mac.
Lovely Rita
Post by Lovely Rita »
Registered User :wink:
Buy MakeMKV
Tom Swyft
Post by Tom Swyft »
No manual mode box on mine for some reason. (I also can't seem to upload a screen shot proving as much; it says:
Sorry, the board attachment quota has been reached
Any thoughts?
MakeMKV v1.10.2
Attachments haven't worked for a long time. If you have access to any other server you can post a link to the picture inside of "img" tags.
Off-hand, the only thing that I know that could be an issue is if you are somehow running a version prior to manual mode being introduced, but that would mean it's at least two years old, and you would have noticed other new features not working, like opening recent BDs.
Tom Swyft
Post by Tom Swyft »
Well, it's definitely the latest version for os x (just downloaded it), definitely a DVD, and definitely doesn't have the tick box to activate manual mode.
I know I sound crazy, but I'm definitely not. :)
Any other thoughts would be helpful. Thanks!
ShinyD
Post by ShinyD »
I believe the step needed to have Manual mode available is to have Expert mode enabled in Preferences.
[Preferences > General (tab/button) > Expert mode (check box)]
You may need to restart MakeMKV.
Then your window should look similar to what Lovely Rita posted.
Tom Swyft
Post by Tom Swyft »
That did it! Thanks for the info!
