Moving key
Bdadtoo
Moving key
Post by Bdadtoo » Tue Nov 15, 2016 3:45 pm
Morning. I've been using MakeMKZV (paid for it) on a PC that I am retiring and want to move to a new box. How do I go about transferring the key? Is there a file or registery entry that can be moved?
Re: Moving key
Post by Woodstock » Tue Nov 15, 2016 4:53 pm
Install MakeMKV on the new machine, then put in your registration key from your email. That's the only way I know to do it.
sflesch
Re: Moving key
Post by sflesch » Sat Nov 19, 2016 5:48 pm
Somewhat related. I assume your response means the license is transferable.
Do you know if it can be used on more than one PC? I generally rip on my home PC, but I just picked up a fast PC at work that I could use (for personal purposes) to rip some disks if I wanted too...Of course I'm limited to 4TB which is mostly full, so that may have to wait a bit.
Re: Moving key
Post by Woodstock » Sun Nov 20, 2016 2:37 am
As I remember things, the license is for "one user". If you're not letting others use your work machine to rip while you're at home ripping, I think that qualifies.
I have it installed on 3 machines, but I'm the only one using any of them.
jmichaeljaffe
Re: Moving key
Post by jmichaeljaffe » Thu Apr 26, 2018 12:52 pm
Last year, I bought MakeMKV for my Linux-based laptop. I am now using a Windows-based laptop. I tried using the same key from my Linux system to my Windows system, but it does not work. How can I transfer my license to my new Windows system?
jmichaeljaffe
Re: Moving key
Post by jmichaeljaffe » Thu Apr 26, 2018 12:56 pm
Nevermind... I retried the key and it worked.
