Problem converting discs
davelamuncha
#1 Post by davelamuncha » Wed Nov 16, 2016 9:45 pm
I have done this many times before but never ran into this. I get the following errors when trying to convert a number of discs.
Not sure where to look next, it isn't a directory or name problem.
MakeMKV v1.10.2 darwin(x86-release) started
Optical drive "DVD+R-DL TSSTcorp DVD+-RW TS-U633F D500d" opened in OS access mode.
Optical drive "BD-ROM WD Virtual CD 1110 1030" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #2 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #4 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 was added (1 cell(s), 0:25:51)
Title #2 was added (1 cell(s), 0:25:51)
Title #3 was added (1 cell(s), 0:25:48)
Title #4 was added (1 cell(s), 0:25:21)
Title #5 was added (1 cell(s), 0:25:22)
Title #6 was added (1 cell(s), 0:25:52)
Title #8 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:25:51)
Title #10 was added (1 cell(s), 0:25:51)
Title #11 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/1 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/2 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/3 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 1 is equal to title 1 and was skipped
Title 2 in VTS 2 is equal to title 1 and was skipped
Saving 6 titles into directory /Volumes/Movie drive/Superman/Season 1/Disk 1
Failed to save title 0 to file /Volumes/Movie drive/Superman/Season 1/Disk 1/ADVENTURES_OF_SUPERMAN_DISC_ONE_t00.mkv
Failed to save title 4 to file /Volumes/Movie drive/Superman/Season 1/Disk 1/ADVENTURES_OF_SUPERMAN_DISC_ONE_t04.mkv
4 titles saved, 2 failed
