Download SVQ fail's
Udo017
Download SVQ fail's
Post by Udo017 »
I get a message in the log:
Automatisches Herunterladen von SVQ ist deaktiviert oder fehlgeschlagen.
"Automatic download of SVQ is not activated or fail."
What can I do if I behind a firewall and need a proxy for internet connections ? Is there a option to set a proxy server ? I did not found this.
Re: Download SVQ fail's
Since you are able reach this site, your firewall should allow updates (including SVQ files), UNLESS your firewall has specific rules for the makemkv program itself. As far as I am aware, MakeMKV will use the same proxy settings as Internet Explorer, so the proxy should not be an issue.
Udo017
Post by Udo017 »
My browser (and all other program's that need internet) has an option to set an proxy server. So I can access it. I didn't set an system wide proxy. If I do
$: export http_proxy="proxy.server:port"
$: makemkv
in a terminal then it work's :-)
I think is is a good idea to create a option for proxy setting's.
