Mechanic: Resurrection-Correct playlist?
LionsGate
#1 Post by LionsGate » Sat Nov 12, 2016 7:48 am
anyone knows? thanks!
yorgo
Re: Mechanic: Resurrection-Correct playlist?
#2 Post by yorgo » Sat Nov 12, 2016 3:02 pm
Rental or purchase? Where rented or where purchased? What nationality/region?
hvnphoto
#3 Post by hvnphoto » Sun Nov 13, 2016 9:41 pm
Title information
Name: Mechanic: Resurrection
Source file name: 00466.mpls
Duration: 1:38:38
Chapters count: 16
Segment count: 20
Segment map: 515,516,505,504,518,520,507,510,517,501,509,513,503,512,511,519,514,502,506,508
File name: Mechanic_Resurrection_t183.mkv
RickInHouston
#4 Post by RickInHouston » Tue Nov 22, 2016 3:40 pm
hvnphoto wrote:Title information
Duration: 1:38:38
Chapters count: 16
Segment count: 20
All rental file sizes are 19.8 GB.
bigga747
#5 Post by bigga747 » Tue Nov 22, 2016 4:24 pm
Does anyone know the correct MPLS for the RedBox version?
JediSamReye
#6 Post by JediSamReye » Tue Nov 22, 2016 5:57 pm
I just made an account to say this. I just checked with procmon and it is pointing to MPLS 00554.pls as the correct playlist for redbox. I am ripping now and I will check it
EDIT - This isn't it, don't waste your time with that playlist, I will keep working
393 Seems to be the correct one at the moment, however I am watching this movie for the third time to be 100% correct
RickInHouston
#7 Post by RickInHouston » Tue Nov 22, 2016 6:49 pm
I got 554, as well, but it is incorrect. The sequence where he goes back to his boat and then to his secret locker with all his identity stuff is out of sequence.
This is another one of those that's more difficult, but can be found other ways...
JediSamReye
#8 Post by JediSamReye » Tue Nov 22, 2016 7:22 pm
Yep I came back here to report, it was also showing 946 so I am trying that now. But yes I saw the same issues you did
nick2421
#9 Post by nick2421 » Tue Nov 22, 2016 7:47 pm
Netflix US coming back with
Title information
Comment: FPL_MainFeature
Source file name: 00393.mpls
Duration: 1:38:38
Chapters count: 16
Segment count: 20
Segment map: 510,518,503,506,519,502,501,508,507,513,516,515,504,511,514,517,509,505,512,520
File name: Mechanic_Resurrection_t00.mkv
Is this correct?
JediSamReye
#10 Post by JediSamReye » Tue Nov 22, 2016 7:54 pm
ok still not it with 946 going to attempt or 393
vh5150
#11 Post by vh5150 » Tue Nov 22, 2016 8:06 pm
393 worked for me on the RB US edition.
bigga747
#12 Post by bigga747 » Tue Nov 22, 2016 9:34 pm
I don't see a 393 Jumps from 389 to 398
cswackha
#13 Post by cswackha » Tue Nov 22, 2016 9:43 pm
For US Redbox I also got 554 using procmon. Why does this not work. Am I not using procmon properly?
Title information
Source file name: 00554.mpls
Duration: 1:38:38
Chapters count: 16
Segment count: 20
Segment map: 510,503,518,506,519,507,515,516,502,501,513,508,504,511,517,514,509,505,512,520
File name: Mechanic_Resurrection_t222.mkv
PS I attempted to attach the PML file but it hard issues uploading for some reason.....
RickInHouston
#14 Post by RickInHouston » Tue Nov 22, 2016 9:46 pm
bigga747 wrote:I don't see a 393 Jumps from 389 to 398
Look up at the very top of the list. It's not down amongst all the others in numerical order.
JediSamReye
#15 Post by JediSamReye » Tue Nov 22, 2016 9:59 pm
Ok I have watched this movie a few times now, each time I found a jump cut I started again, the last one I did was 393 and it appears 100% correct, I haven't seen the movie before this adventure, but everything seemed like a correct story path, there was only one scene I thought looked like a harder cut then normal, so then I fired up the movie and watched that part directly from the disc and it played the same, so that is normal.
So I am going to say CONFIRMED 393 for US RB
