Terrordactyl correct title / Problems though
Krawk
Post by Krawk »
Just a heads up on a new release named Terrordactyl in the USA Region 1.
It appears the correct title is title 1, not title 0. If you rip title 0 your first chapter will basically put your media player on PAUSE. If you skip further into it, it is all a test pattern with the lovely tone. It will not harm you to rip title 0 but then when you re-encode you need to encode chapters 2-13 (skipping chapter 1.)
This makes no sense to me logically though because the segment map for both titles begins with 1.
Title 0 - Segment 1-13
Title 1 - Segment 1-12
Also, the Monkey seems to rip the first title correctly, so where the extra chapter comes from is beyond me. And rips created with MakeMKV seem to have the AR set wrong while the AR from DvdFab is correct.
Is this an IFO issue or something?
And where does the test pattern chapter come from, seriously?
