Multiple playlist for "The Lobster"
ingen1ous
Re: Multiple playlist for "The Lobster"
Post by ingen1ous »
Apologies...playlist 620 is on the disc for UPC 031398247432 and MakeMKV correctly identified it as the main playlist.
kihilind
Post by kihilind »
Can anyone help with the Netflix version that lacks a playlist 620?
carboranadum
Post by carboranadum »
kihilind wrote:Can anyone help with the Netflix version that lacks a playlist 620?
Look at the top of the disk. It is labeled "MAIN FEATURE". It's not sorted numerically.
Ripmaster
Post by Ripmaster »
It's a bit of a PITA to find the right one. The file you want is 71 from the bottom and scrolling makes it almost impossible to count. Here's how to do it; First, deselect all files. From the bottom file count up ten. Put a place-saving check in that file, then count up ten again, place another check-and so on until you get to 70 from the bottom. The correct file is 71 from the bottom. BTW, it is the only file that has 505, 502, 503, 514 in that order, so check that you have that sequence. Hope this helps and remember to remove your place-saving checks!
the full sequence is: 00505, 00502, 00503, 00514, 00511, 00508, 00513, 00512, 00510, 00509, 00506, 00501, 00515, 00507, 00504
Slogger
Post by Slogger »
kihilind wrote:I also have Netflix version, Region 1, and also don't have 620. Any other ideas?
For those that can't find 620 on the Netflix version, look at the very top of the list, the one that says "FPL_MainFeature" It's not in order with the rest of the numbered items.
