Unable to convert hunger games mockingjay part 1&2
saltmar14
Post by saltmar14 »
MakeMKV v1.10.2 win(x64-release) started
Cells 2-6 were skipped due to cell commands (structure protection?)
Title #1 was added (20 cell(s), 2:07:00)
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (6 cell(s), 0:11:15)
Title #7 was added (6 cell(s), 0:11:15)
Title #8 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:04:10)
Title #10 was added (9 cell(s), 0:11:12)
Title #11 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 was added (1 cell(s), 0:03:05)
Title #15 was added (1 cell(s), 0:02:17)
Title #16 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 was added (1 cell(s), 0:23:00)
Title #22 was added (1 cell(s), 0:20:20)
Title #25 was added (22 cell(s), 2:07:13)
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #26 was added (19 cell(s), 2:02:32)
Title #27 was added (20 cell(s), 2:07:00)
Title #28 was added (19 cell(s), 2:02:32)
Title #29 was added (20 cell(s), 2:07:00)
Title #30 was added (19 cell(s), 2:02:32)
Title #31 was added (20 cell(s), 2:07:00)
Title #34 was added (19 cell(s), 2:02:32)
Title #35 was added (22 cell(s), 2:07:13)
Title #36 was added (22 cell(s), 2:07:13)
Title #37 was added (19 cell(s), 2:02:32)
Title #38 was added (22 cell(s), 2:07:13)
Title #39 was added (22 cell(s), 2:07:13)
Title 1 in VTS 14 is equal to title 1 and was skipped
Title 2 in VTS 14 is equal to title 1 and was skipped
Title 1 in VTS 21 is equal to title 1 and was skipped
Saving 1 titles into directory L:/Video
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 86016, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 761751552, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1169539072, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1558306816, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 2211340288, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 2657646592, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 3009773568, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 3325243392, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 3717394432, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 290340864, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 658032640, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1139075072, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1491300352, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1544161280, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 301594624, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1017931776, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1018464256, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1018853376, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1019242496, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1019631616, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1020020736, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1020409856, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1020798976, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1021188096, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1021577216, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1021966336, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1022355456, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1022744576, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1023133696, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1023522816, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1023911936, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1024301056, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1024690176, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1025079296, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1025468416, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1025857536, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1026246656, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1026635776, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1027024896, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1027414016, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1027803136, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1028192256, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1028581376, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1028970496, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1029359616, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1029748736, attempting to work around
The source file '/VIDEO_TS/VTS_15_1.VOB' is corrupt or invalid at offset 1030137856, attempting to work around
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_15_1.VOB' at offset '1030363136'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '1030363136'
Failed to save title 0 to file L:/Video/title00.mkv
0 titles saved, 1 failed
Re: Unable to convert hunger games mockingjay part 1&2
Most likely issue (assuming you've got the correct file to convert... Hunger Games movies are subject to play list obfuscation) is that you have a dirty disk, especially since the errors seem to be able to "correct" themselves with multiple retries. Clean the disk with a damp, soft cloth, and try the rip again.
You might also try increasing the number of retries used on read, in Preferences->IO, to ask the drive more times to try the read.
saltmar14
Post by saltmar14 »
Thank you it worked. It found 6 full titles it copied 4, 2 failed. it took almost 4 hours.
