makemkvcon prompting for evaluation period
byrdclaw
Post by byrdclaw » Wed Nov 02, 2016 2:45 am
I'm trying to use makemkvcon to script a conversion process. When I launch the command I'm given the following output
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5053,776,1,"This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?","This functionality is shareware. You may evaluate it for %1 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?","30"
MSG:5010,0,0,"Failed to open disc","Failed to open disc"
Is there anything i can pass through the command to force this to work, or is there something I can agree to in the GUI to test this functionality further?
Re: makemkvcon prompting for evaluation period
Post by Woodstock » Wed Nov 02, 2016 10:53 am
You need to reset the 30-day counter on the Bluray functionality. In the GUI, go to Help->Register, and re-enter the current beta key, which can always be found here: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
