Happily Ever After
andcbii
Happily Ever After
Post by andcbii »
I've got a DVD of Happily Ever After. For some reason the first 9 minutes(the entire first chapter) of the film aren't riped with the main title. This all the log file shows:
Debug log started at Tue Nov 01 23:10:05 2016 , written by MakeMKV v1.10.2 win(x64-release)
001005:0000 MakeMKV v1.10.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Andrew/MakeMKV_log.txt
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
Title skip vts=1 pgcn=1 hash=1E27C7392FA2C612
003024:1000 Complex multiplex encountered - 13 cells and 6282 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #1/0/1 was added (13 cell(s), 1:30:33)
003025:0000 Title #3 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 1 cells and 828 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #4 was added (1 cell(s), 0:11:56)
Title skip vts=2 pgcn=2 hash=429C0B517AA63CFE
003024:1000 Complex multiplex encountered - 1 cells and 208 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #5 was added (1 cell(s), 0:02:59)
Title skip vts=2 pgcn=3 hash=E42A272DE778301B
003025:0000 Title #6 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003024:1000 Complex multiplex encountered - 2 cells and 195 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #7 was added (2 cell(s), 0:02:48)
Title skip vts=3 pgcn=1 hash=B8FF036DDA4BA258
005014:0000 Saving 1 titles into directory //rackstation/Media/New Rips/HAPPILY_EVER_AFTER
004007:0010 AV synchronization issues were found in file '//rackstation/Media/New Rips/HAPPILY_EVER_AFTER/title00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 0:00:00.021 with duration of 96ms : 3 early frame(s) dropped at start
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Tue Nov 01 23:51:22 2016
Any idea why the full film will not rip. I tried ripping all the titles but the begining of the film isn't on any of them.
Re: Happily Ever After
I'd suggest sending the information asked for in the FAQ in my signature to support@makemkv.com , in case there is more than one title that seems like the main feature.
andcbii
Post by andcbii »
Woodstock wrote:I'd suggest sending the information asked for in the FAQ in my signature to support@makemkv.com , in case there is more than one title that seems like the main feature.
Does what i posted look like full log file? I was expecting the file to be much bigger.
Log files are not necessarily large, when everything goes as expected. But what is saved to disk is usually larger than what is shown on the screen.
In your case, the "full log" would be found at C:\Users\Andrew/MakeMKV_log.txt, so log as you fetch it right after exiting MakeMKV. Each time MakeMKV starts, it erases the old log.
andcbii
Post by andcbii »
What i posted above is what was in that log file.
