I think, with this release, the automatic destination (output) folder naming is broken. At least, under Debian it seems to be.
Going to Preferences / Video / Default Destination and selecting None, Auto, SemiAuto or Custom then Apply / OK, does not seem to make a difference. The path presented after parsing a disk for titles always matches the last path a disk was saved to.
With previous releases, the path would be composed of a root folder and the disk title.
Thanks for a fine product!
Cheers.
1.10.2 - automatic destination naming is broken.
bitbug
Re: 1.10.2 - automatic destination naming is broken.
bug discussed, acknowledged, and fix to come "real soon now". Check the General Discussion area
bitbug
Yup. That sounds like the same problem. Thanks for answering.
Cheers.
Cheers.
