1.10.2 - automatic destination naming is broken.
bitbug
Post by bitbug »
I think, with this release, the automatic destination (output) folder naming is broken. At least, under Debian it seems to be.
Going to Preferences / Video / Default Destination and selecting None, Auto, SemiAuto or Custom then Apply / OK, does not seem to make a difference. The path presented after parsing a disk for titles always matches the last path a disk was saved to.
With previous releases, the path would be composed of a root folder and the disk title.
Thanks for a fine product!
Cheers.
Re: 1.10.2 - automatic destination naming is broken.
bug discussed, acknowledged, and fix to come "real soon now". Check the General Discussion area
bitbug
Post by bitbug »
Yup. That sounds like the same problem. Thanks for answering.
Cheers.
