Burning a Season's Series
Tyrone787
Post by Tyrone787 »
If I want to burn a season's series of a TV show's DVD, how can I set up the MKV program to burn the entire DVD, so I can select a specific episode from the copied MKV file?
Re: Burning a Season's Series
MakeMKV does not author DVDs or BDs. You need special software for that (some of which is available for free), that accepts MKV files as input.
